josefdoc
 Share
Hi, I waxed my car with an orbital polisher back in October 2017. It's time for another coat of wax after the winter and was wondering if I had to remove the previous coat of wax or if it already wore off.
Thank You!
4 answers to this question
Chances are if you used a carnuba wax it has worn off already, if you used paint sealant it may be going strong still. It depends a lot on maintenance routine as well. If you want to be safe you could always wash first with strip was or an equivalent type of product.
:iagree:. You should be able to tell once you pre-rinse the car before washing. Check the water behavior, and if it isn't beading and sheeting then your previous layer of protection is gone. Either way, it's always nice to start with a clean slate if you're uncertain.
Answer this question...
 Share
