Hookem06 Posted August 22, 2018 Posted August 22, 2018 I used Adam’s products on my vehicles, side by sides, Cessna & Piper plane, & boat. Trying something new, I have several white Yeti coolers, also pelican & RTIC brands. What product would be good for for removing the dirt stains on top and stained coloration inside the coolers? Any suggestions would be great. Ive done the dishwashing soap, scrub, etc. That method just leaves it smelling good on the inside.
0 Hookem06 Posted August 22, 2018 Author Posted August 22, 2018 54 minutes ago, Velvethelmet said: Vinegar water Ive done that. Still have the “brown water stain” on the inside... i did have the water mark/lines on my jet skis, and used a few combinations of Adam’s & chemical guys products... and it worked... but no no go on any of the coolers
0 crrafferty89 Posted August 22, 2018 Posted August 22, 2018 3 hours ago, Hookem06 said: I used Adam’s products on my vehicles, side by sides, Cessna & Piper plane, & boat. Trying something new, I have several white Yeti coolers, also pelican & RTIC brands. What product would be good for for removing the dirt stains on top and stained coloration inside the coolers? Any suggestions would be great. Ive done the dishwashing soap, scrub, etc. That method just leaves it smelling good on the inside. Use the original soft scrub like you use on your boats to clean them! I've found that is by far the best product to use on Yeti Coolers. If you have spots you can also make a bleach paste, apply and let sit for a while then clean off. That usually works as well. Hookem06 1
0 falcaineer Posted August 22, 2018 Posted August 22, 2018 Interior scrub mitt? Maybe use the LIC, too. Hookem06 1
0 Black Bowtie Posted August 23, 2018 Posted August 23, 2018 Blow up the Yeti!! They went weak and stopped being a sponsor to the NRA. I have gotten rid of all my Yeti products. ?? Mbrazelton, ZMAN024, TJM and 1 other 3 1
0 Editguy Posted August 23, 2018 Posted August 23, 2018 (edited) 48 minutes ago, Black Bowtie said: Blow up the Yeti!! They went weak and stopped being a sponsor to the NRA. I have gotten rid of all my Yeti products. ?? Time to buy a Yeti! Edited August 23, 2018 by Editguy tmccoy2236 and Genuine 2
0 Hamilton Detail Posted August 23, 2018 Posted August 23, 2018 I use the all purpose cleaner and it usually does the trick. wildcatz80 1
0 Black Bowtie Posted August 23, 2018 Posted August 23, 2018 1 hour ago, Editguy said: Time to buy a Yeti! Yeti was supposedly for the outdoors person hunter/fisherman, I will be damned If I will give any money to a company that has a knee jerk reaction to the anti gun liberals. Dicks Sporting goods and REI are two others. I was a member of REI for over 40 years and will no longer step in their doors or buy for them online. Plus YETI was made here in Iowa and closed the plant. Now I think everything is made in China or the Philippines. ZMAN024 and Velvethelmet 2
0 Hookem06 Posted August 23, 2018 Author Posted August 23, 2018 1 hour ago, Hamilton Detail said: I use the all purpose cleaner and it usually does the trick. Ive used eco APC and, scrubbed... no luck
0 wildcatz80 Posted August 23, 2018 Posted August 23, 2018 (edited) 1 hour ago, Hamilton Detail said: I use the all purpose cleaner and it usually does the trick. I do the same but with Adams deep clean eraser or magic sponge. I will upload pictures when I get home. Edited August 23, 2018 by wildcatz80
0 wildcatz80 Posted August 23, 2018 Posted August 23, 2018 12 minutes ago, Hookem06 said: Ive used eco APC and, scrubbed... no luck Can you show us a picture of it?
0 Hookem06 Posted August 24, 2018 Author Posted August 24, 2018 On 8/23/2018 at 10:31 AM, wildcatz80 said: Can you show us a picture of it? Pics of finished and cleaned, was 20x worse. Still kinda water stained but better Used APC and CG orange degreaser Sat for several hrs w/ APC
0 falcaineer Posted August 24, 2018 Posted August 24, 2018 1 hour ago, Hookem06 said: Pics of finished and cleaned, was 20x worse. Still kinda water stained but better Used APC and CG orange degreaser Sat for several hrs w/ APC Still thinking the Interior Scrub mitt would work well on this. Your call. Looks much better, though. Hookem06 1
0 Hookem06 Posted August 25, 2018 Author Posted August 25, 2018 2 hours ago, falcaineer said: Still thinking the Interior Scrub mitt would work well on this. Your call. Looks much better, though. Yea, I’m going to spray APC and scrub and see what happens... my pelican is horrible
0 imatt27 Posted August 25, 2018 Posted August 25, 2018 Maybe some hand revive polish or get the SK mini in there
0 Hookem06 Posted August 25, 2018 Author Posted August 25, 2018 1 hour ago, imatt27 said: Maybe some hand revive polish or get the SK mini in there Definitely NEVER thought of using that combo on the inside of a cooler. Now the one step & 15mm worked wonders on my Honda aquatrax
0 J Rosson Posted August 29, 2018 Posted August 29, 2018 Try a MR. Clean magic eraser. Works on mine everytime.
Hookem06
17 answers to this question
