donnielongtin Posted September 11, 2018 Share Posted September 11, 2018 I recently purchased the adams foam cannon and the snub nose power washer gun. Im trying to get that "Shaving Cream" foam that I see if videos where it really cakes on the car and doesn't run off right away. Ive messed with the settings on the cannon, Ive tried adding way more soap to the cannon and its still really watery. What am I doing wrong? Some help would be great. Thanks. Quote Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted September 11, 2018 Share Posted September 11, 2018 What are the pressure washer specs? Are you using the 1.1mm orifice? Where are you setting the mixture knob on the top of the gun (it controls the amount of water going through. Clockwise is less water)? Quote Link to comment Share on other sites More sharing options...
0 wildcatz80 Posted September 11, 2018 Share Posted September 11, 2018 I had the same issue when I got my foam cannon. It wasn't like what it looked in adamspolishes video. I order this ordered 1.1mm orifice. Made a huge difference I have a electric pressurewasher. https://www.mtmhydroparts.com/collections/pressure-washing/products/copy-of-replacement-orifice-foam-cannon-nozzle Quote Link to comment Share on other sites More sharing options...
0 Editguy Posted September 11, 2018 Share Posted September 11, 2018 Does the Adams Foam Cannon come with the 1.1 orifice included? Quote Link to comment Share on other sites More sharing options...
0 donnielongtin Posted September 11, 2018 Author Share Posted September 11, 2018 gas pressure washer. 1700 PSI, but has seen better days. (New one is on the purchase list) Adams Ultra foam for the soap. Water is damn near closed off on the foam cannon itself. Just ordered the 1.1mm orifice. well see if that helps. Thanks for the feedback. Appreciate all the help. Will send an update. Quote Link to comment Share on other sites More sharing options...
0 falcaineer Posted September 11, 2018 Share Posted September 11, 2018 5 hours ago, wildcatz80 said: I had the same issue when I got my foam cannon. It wasn't like what it looked in adamspolishes video. I order this ordered 1.1mm orifice. Made a huge difference I have a electric pressurewasher. https://www.mtmhydroparts.com/collections/pressure-washing/products/copy-of-replacement-orifice-foam-cannon-nozzle You ridin' that Jeep on Adam's buckets and dollies?! ObsessedDetailer, mexiking2365 and wildcatz80 1 2 Quote Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted September 12, 2018 Share Posted September 12, 2018 21 hours ago, Editguy said: Does the Adams Foam Cannon come with the 1.1 orifice included? I don’t believe so. Quote Link to comment Share on other sites More sharing options...
0 Devon527 Posted September 12, 2018 Share Posted September 12, 2018 I can tell you it has alot to do with the pressure washer. I had a cheap greenworks pressure washer and I thought it worked great. Then I bought a Kranzle and that alone gave me a ton more foam with the same foam cannon. Quote Link to comment Share on other sites More sharing options...
-1 rseward Posted September 11, 2018 Share Posted September 11, 2018 What soap are you using? I've heard the better your pressure washer the better the foam, in other words, a gas pressure washer will produce better foam than most electric pressure washers. I've had good results using Adams Car Shampoo in a generic foam cannon from Amazon with a BlackMax electric pressure washer rated at 1700 PSI and 1.2 GPM. I believe I had to turn the top knob to the closed position (or almost closed), for the best results. Quote Link to comment Share on other sites More sharing options...
donnielongtin
Thanks.
8 answers to this question
