buffalobob920 Posted September 16, 2018 Share Posted September 16, 2018 Hi I have a question on what is the best way to remove a melted lollipop from an interior carpet Quote Link to comment Share on other sites More sharing options...
0 RayS Posted September 16, 2018 Share Posted September 16, 2018 I found a thread on the topic from not to long ago: There are comments down in the thread about not using heat since it will melt the candy more. My resident expert, "wife", said to use the cold method for getting it out. Quote Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted September 16, 2018 Author Share Posted September 16, 2018 5 minutes ago, RayS said: I found a thread on the topic from not to long ago: There are comments down in the thread about not using heat since it will melt the candy more. My resident expert, "wife", said to use the cold method for getting it out. Thanks that makes a lot of sense Quote Link to comment Share on other sites More sharing options...
0 Beemer Posted September 16, 2018 Share Posted September 16, 2018 You could try licking it. Sorry. Couldn't help myself. mc2hill 1 Quote Link to comment Share on other sites More sharing options...
0 Bscott94 Posted September 16, 2018 Share Posted September 16, 2018 I used an ice pack and had pretty good luck. It didn’t come out completely but it is way better RayS and mc2hill 2 Quote Link to comment Share on other sites More sharing options...
0 falcaineer Posted September 16, 2018 Share Posted September 16, 2018 Do you have the multi purpose foaming cleaner? Quote Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted September 17, 2018 Author Share Posted September 17, 2018 38 minutes ago, falcaineer said: Do you have the multi purpose foaming cleaner? Yes I do Quote Link to comment Share on other sites More sharing options...
0 Rich Posted September 17, 2018 Share Posted September 17, 2018 ICE! Freeze it first, then you can peel it off. After you peel it off, then soak it with water and blot as much off as you can. Then use some Carpet and Upholstery Cleaner on the whole area, otherwise you'll end up with a clean spot. mc2hill 1 Quote Link to comment Share on other sites More sharing options...
0 falcaineer Posted September 17, 2018 Share Posted September 17, 2018 1 hour ago, buffalobob920 said: Yes I do It's great stuff. Once most residue is gone, give it a try to get the rest. Quote Link to comment Share on other sites More sharing options...
0 CoonHound693 Posted September 17, 2018 Share Posted September 17, 2018 Use canned air upside down and freeze and pick. Quote Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted September 17, 2018 Author Share Posted September 17, 2018 Thanks for your help Quote Link to comment Share on other sites More sharing options...
buffalobob920
10 answers to this question
