Hi all, first time post here. Hope everyone is keeping safe and healthy.
Have used the AP foam cannon a couple of times now, and each time I'm getting the same consistency -- the foam output is very thin and is running down the car like water, which is a far cry from the YouTube videos where the foam is thick and stays on the car. II've also noticed that the pressure is quite weak, although my pressure washer seems to be working just fine without foam cannon attachment.
The pressure washer I'm using is the Sun Joe SPX3000, with 2030 max PSI and 1.76 GPM, both are within range of AP's requirements. I've also adjusted the water to foam ratio but still getting the same consistency. Just generally confused so hopefully the kind folks here can provide any insights.
On a separate note, the Air Cannon Dryer has been phenomenon for me!
jhleung
6 answers to this question
