ADG Posted November 30, 2020 Share Posted November 30, 2020 Please tell me a few top products (as little as possible for now) starting out? I will be using a pressure washer, so I am wanting to know if a foam cannon would even be necessary? My vehicle gets moderately dirty. Please tell me the best products for a newbie: 1. Wash 2. Mitten/brush 3. Tire Cleaner 4. Bug remover 5. Foam cannon or not? Thank you so much for any helpful suggestions and feedback. I can't wait to hear your suggestions. ADG Link to comment Share on other sites More sharing options...
0 falcaineer Posted November 30, 2020 Share Posted November 30, 2020 Check out this article for more on using foam during your wash. https://adamspolishes.com/blogs/news/why-foam I'll add some kit or product recommendations later today. Link to comment Share on other sites More sharing options...
0 RayS Posted December 1, 2020 Share Posted December 1, 2020 I have a foam cannon and foam gun and have found that I use the Foam Gun much more than the foam cannon. The foam gun is quicker to get set up and to clean and both put out plenty of foam. For very dirty vehicles, then the foam cannon comes out along with the pressure washer and extra stuff required. The same goes if I am doing multiple vehicles in the day, the foam cannon becomes worth the extra setup and clean up time. The one thing that I have done for all my hoses and nozzles is to add quick connects and a shutoff valve on the end of the hose. This makes it real easy to switch nozzles or go from the pressure washer to a nozzle or between the foam gun and a nozzle without having to go back to the spigot to turn off the water. ADG 1 Link to comment Share on other sites More sharing options...
0 ADG Posted December 1, 2020 Author Share Posted December 1, 2020 2 minutes ago, RayS said: I have a foam cannon and foam gun and have found that I use the Foam Gun much more than the foam cannon. The foam gun is quicker to get set up and to clean and both put out plenty of foam. For very dirty vehicles, then the foam cannon comes out along with the pressure washer and extra stuff required. The same goes if I am doing multiple vehicles in the day, the foam cannon becomes worth the extra setup and clean up time. The one thing that I have done for all my hoses and nozzles is to add quick connects and a shutoff valve on the end of the hose. This makes it real easy to switch nozzles or go from the pressure washer to a nozzle or between the foam gun and a nozzle without having to go back to the spigot to turn off the water. Wow! Thank you so much for your reply. I will be using a pressure washer. Are you using the foam gun with a pressure washer (I'm assuming not)? I appreciate your help! Link to comment Share on other sites More sharing options...
0 RayS Posted December 1, 2020 Share Posted December 1, 2020 The Foam Gun works with just your garden hose, you can't use a pressure washer with it. The Foam Cannon requires a pressure washer for it to be used. ADG 1 Link to comment Share on other sites More sharing options...
ADG
1. Wash
2. Mitten/brush
3. Tire Cleaner
4. Bug remover
ADG
4 answers to this question
