KeninRWTX Posted February 12, 2021 Share Posted February 12, 2021 So how much pressure and what flow rate is really sufficient to remove old, flaky paint/stain from a wood fence? I can actually remove much of it with a garden hose, so it seems a great amount of pressure is not necessary, but the garden hose uses a lot of water and is too slow to do a large area. Link to comment Share on other sites More sharing options...
Dan@Adams Posted February 17, 2021 Share Posted February 17, 2021 Hi @KeninRWTX, an electric pressure washer with a psi over 1000 should remove flaky paint from a wood fence. There are a few cautions though to not damage the fence: - Keep the pressure washer wand at least 12" away from the wood surface - Do NOT use a 0° nozzle tip on the pressure washer handle, as it can damage wood (0° nozzle tip is usually used for cleaning stains from concrete) - I would be hesitant to use use a 15° nozzle tip as well, as it would still be a very powerful stream - A 25° or 40° nozzle tip is what I would start out with in a small test area. Our Pressure Washer 2.0 would be a great option for use around the yard as well as your vehicle, since it has a 35-foot power cord and a 40-foot hose for the Snub Nose Handle. It has a working pressure of 1700PSI at a flow rate of 1.4GPM, and you can find it here: https://adamspolishes.com/products/adams-pressure-washer We have a 15% off sale running as well, which would bring the price down under $300 before taxes, and it would qualify for free shipping. Link to comment Share on other sites More sharing options...
Rich Posted February 17, 2021 Share Posted February 17, 2021 Welcome to the forum. I have a wood privacy fence that I pressure wash fairly often. Like Dan said, don't get real close if you're using a straight spray. Instead, set it so it fans out. You can get a little closer with that kind of spray. But you're not going to get all the paint off with a pressure washer either. Which is why I just have mine stained and water sealed. I spray wash to remove the dirt and mildew, and then reseal the wood. Link to comment Share on other sites More sharing options...
