ayorayj 0 Posted March 11 Share Posted March 11 I’ve had the graphene spray coating on my car for about 6 months. I decided I want to up grade to the full graphene ceramic coating. What’s the easiest way to remove the spray coating without polishing or compounding? Quote Link to post Share on other sites
0 BRZN 1,168 Posted March 11 Share Posted March 11 It takes mechanical action to remove a Ceramic Coating. You're going to have to machine polish it off. I was able to remove the regular SiO2 Ceramic Coating with a Microfiber Pad and Compound and a bit of work. The Spray Coating should come off much easier, especially after being on the vehicle for six months. If a little remains you should be fine since they're two similar chemicals and will bond to each other as long as the original layer isn't too substantial. Be sure to thoroughly wipe the vehicle down with Surface Prep before application. Norton and falcaineer 2 Quote Link to post Share on other sites
0 ayorayj 0 Posted March 12 Author Share Posted March 12 You think claying the car might clear most of it off? I’m trying not to polish the car if I don’t have to. Quote Link to post Share on other sites
0 The Guz 295 Posted March 12 Share Posted March 12 Polishing will you give you the best base for the coating to bond. It will for sure remove the spray coating. Claying won't do it. falcaineer 1 Quote Link to post Share on other sites
0 Chris@Adams 2,258 Posted March 12 Share Posted March 12 6 hours ago, ayorayj said: You think claying the car might clear most of it off? I’m trying not to polish the car if I don’t have to. Clay won't remove the Spray Coating you will have to machine polish to remove it. falcaineer 1 Quote Link to post Share on other sites
0 falcaineer 4,466 Posted March 12 Share Posted March 12 Agreed with the above comments, you'll need to polish with a machine. Think of it as a bit more time invested before locking it in for years. Quote Link to post Share on other sites
0 ayorayj 0 Posted March 15 Author Share Posted March 15 I just did a one step a few months ago. Just trying to save a much clear coat as I can. Quote Link to post Share on other sites
0 falcaineer 4,466 Posted March 15 Share Posted March 15 9 hours ago, ayorayj said: I just did a one step a few months ago. Just trying to save a much clear coat as I can. You really aren't removing all that much, and the coating will protect the remainder for years to come. If you don't polish it off, the new coating won't fully bond properly. I foresee you'll need to remove it again down the road due to diminished performance and probably sooner than you otherwise would've, meaning polishing it all over again anyway. Ultimately, it's your car, but to get the best results, you'll want to remove as much of the Spray Coating as possible before applying the traditional coating, and that means using the machine. Quote Link to post Share on other sites
ayorayj 0
Link to post
