Kickerz71 Posted May 23, 2021 Share Posted May 23, 2021 Just a question will the coating cause issues when the wheel weights are installed. Will they have a hard time to stick on the wheel? im waiting on a new set and not sure if I should coat prior to tire install or wait until it’s balance and the tire is on thank you Link to comment Share on other sites More sharing options...
0 falcaineer Posted May 23, 2021 Share Posted May 23, 2021 Yes, it can cause issues, weights can become dislodged from the wheels. I would recommend you get them mounted and balanced first and then coat. Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted May 24, 2021 Share Posted May 24, 2021 I suggest not coating the area where the weights would go. You could use a line of masking tape over that section. That way if the wheels have to be rebalanced down the road you won’t have to remove the coating when weights are moved. Link to comment Share on other sites More sharing options...
0 The Guz Posted May 24, 2021 Share Posted May 24, 2021 Wait until you get the tires mounted and balanced. The tire sop will make a bit of a mess and you will need to clean them up a bit. As mentioned about the weights as well. Link to comment Share on other sites More sharing options...
0 Kickerz71 Posted June 2, 2021 Author Share Posted June 2, 2021 Update - I received my ceramic wheel kit. Once I have prepared my wheels, I apply the ceramic then once cured I remove with suede towel? The kit came with the suede towel and 2 double soft microfiber towels. Thanks in advance. E Link to comment Share on other sites More sharing options...
0 falcaineer Posted June 3, 2021 Share Posted June 3, 2021 11 hours ago, Kickerz71 said: Update - I received my ceramic wheel kit. Once I have prepared my wheels, I apply the ceramic then once cured I remove with suede towel? The kit came with the suede towel and 2 double soft microfiber towels. Thanks in advance. E Do an initial wipe with the suede to level, then the double soft to remove remaining residue. Link to comment Share on other sites More sharing options...
Kickerz71
thank you
5 answers to this question
