I am new to ceramic coating and I also have lessons to be learned. Last weekend, I washed my car, then clayed it followed by using the surface prep and, finally, the ceramic paint coating. I neither polished between the claying and the applying of the surface prep. Nor did I use Boost after the ceramic paint coating. Currently have a lot of smears. Should I polish before applying the surface prep? If so, any suggestions on a good polish to use? The instructions did not indicate to use Boost as part of the "complete" treatment. Should I use that also?
Mike18
Thoughts on where I should go from here?
Thanks,
Mike
12 answers to this question
