Black Bowtie Posted June 29, 2021 Share Posted June 29, 2021 Can the Adams Surface Prep be used to prep trim when I use Graphene Ceramic Spray Coating, or do I have to use the Trim Prep? Why I ask is I only have the Surface Prep at this time and my local dealer does not carry the Trim Prep. Link to comment Share on other sites More sharing options...
0 falcaineer Posted June 29, 2021 Share Posted June 29, 2021 You can use TRC instead on the trim. Link to comment Share on other sites More sharing options...
0 Black Bowtie Posted June 30, 2021 Author Share Posted June 30, 2021 23 hours ago, falcaineer said: You can use TRC instead on the trim. I am going to use the TRC, but did not know if I needed to follow up with the Trim Prep after? This sentence is from the description for Trim Prep. " This product was developed in unison with our Surface Prep to take care of the bulk of the dirt, while the Surface Prep is a final wipe product to remove any left behind surfactants or residues from Trim Cleaner." Main reason I ask is I purchased this truck new this spring and there is a ton of plastic trim on it and want to do it right the first time and not have to correct a problem after the fact. Link to comment Share on other sites More sharing options...
0 falcaineer Posted June 30, 2021 Share Posted June 30, 2021 11 hours ago, Black Bowtie said: I am going to use the TRC, but did not know if I needed to follow up with the Trim Prep after? This sentence is from the description for Trim Prep. " This product was developed in unison with our Surface Prep to take care of the bulk of the dirt, while the Surface Prep is a final wipe product to remove any left behind surfactants or residues from Trim Cleaner." Main reason I ask is I purchased this truck new this spring and there is a ton of plastic trim on it and want to do it right the first time and not have to correct a problem after the fact. Use one or the other, no need for both. Link to comment Share on other sites More sharing options...
Black Bowtie
3 answers to this question
