liquidred Posted July 11, 2021 Share Posted July 11, 2021 What is the ideal pressure washer power to wash a car? I have one I use that is 3100 psi 2.4 GPM. Is that too strong to wash a car? Link to comment Share on other sites More sharing options...
0 BrianT Posted July 12, 2021 Share Posted July 12, 2021 You can use any pressure you want, just adjust the distance you are from the paint! You should be fine with that setup, just don’t get too close!! Islander 1 Link to comment Share on other sites More sharing options...
0 Islander Posted October 1, 2021 Share Posted October 1, 2021 Very true about keeping your distance. It's easy to forget sometimes and then you can seriously screw up your paint. Personally I like a low powered 1400psi machine in case I forget and get too close. I stay about 18" or so away and only use a 40 degree white tip for paint. Link to comment Share on other sites More sharing options...
0 07stanggt Posted October 13, 2021 Share Posted October 13, 2021 I use a Ryobi 1600 psi (electric) from Home Depot and it works awesome. I have a 3300 psi (gas) that takes paint off of things, to much psi unless you stand back Link to comment Share on other sites More sharing options...
0 TheWolf Posted October 13, 2021 Share Posted October 13, 2021 It is not worth the risk of potential damage by using a high pressure unit. Stay in the 1500-2000 psi range. RacerX 1 Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted October 14, 2021 Share Posted October 14, 2021 On 7/11/2021 at 12:10 PM, liquidred said: What is the ideal pressure washer power to wash a car? I have one I use that is 3100 psi 2.4 GPM. Is that too strong to wash a car? In my opinion that is too powerful, i would go for 1500 to 1800 psi. Link to comment Share on other sites More sharing options...
0 walkthewalk111 Posted November 7, 2021 Share Posted November 7, 2021 If you happen to already own a 3100 psi unit, can't you get a white tip with a large diameter orifice, to lower the pressure to a safer psi? Say something like a 4.5 orifice, as opposed to the normal 1.5. Link to comment Share on other sites More sharing options...
liquidred
6 answers to this question
