From the side of the bottle, Step 5 says the following:
Use a second clean waffle weave towel after all sides on the first towel are fully soiled. Note: Using a clean, dry towel will cause this product to be streaky and not wipe away streak free.
Slightly confused by the note - are we supposed to dampen a new towel before using it? Thought I read elsewhere that you are supposed to come behind the waffle weave with a clean microfiber towel to remove streaks - is that the proper procedure?
LinPark
Thanks!
2 answers to this question
