gred1987 Posted August 19, 2021 Share Posted August 19, 2021 I have been using Adam's products for 10 years now or so, I know how to use them correctly and love their products. Someone keyed my wife's new Pacifica on the front fender, it is a flat ceramic gray color. Busted out the Swirl and Haze remover to see if I could "blend it" to hide it from the eye. Was working well on 70% of the scratches, which is what I was expecting and I am happy with the results. BUT I noticed a dark spot on the paint appear, about the size of a silver dollar. It is to the right of the vertical scratch. Can anyone tell me it is?? Did I burn through the clear coat? It is smooth the touch and not rough or bleeding. Can I fix it with Polish? Link to comment Share on other sites More sharing options...
0 BrianT Posted August 20, 2021 Share Posted August 20, 2021 That is an odd dark spot for sure. I have no idea what it could be. I would however fill the scratch with paint and then top it it with some clear coat. I’d wet sand it smooth, then polish it out. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted August 22, 2021 Share Posted August 22, 2021 Did you use a machine or by hand? Link to comment Share on other sites More sharing options...
0 gred1987 Posted August 24, 2021 Author Share Posted August 24, 2021 On 8/22/2021 at 7:29 AM, Chris@Adams said: Did you use a machine or by hand? I used the porter cable random orbital machine. Link to comment Share on other sites More sharing options...
0 wildcatz80 Posted August 24, 2021 Share Posted August 24, 2021 Hi, It will be multiple things that can cause that like different polishes used, a coated car but only polished spot not entire panel. Did you polished the entire panel or just where it's keyed? I would recommend to do the panel with Polish first if it was not done. Link to comment Share on other sites More sharing options...
0 gred1987 Posted August 26, 2021 Author Share Posted August 26, 2021 On 8/24/2021 at 4:37 PM, wildcatz80 said: Hi, It will be multiple things that can cause that like different polishes used, a coated car but only polished spot not entire panel. Did you polished the entire panel or just where it's keyed? I would recommend to do the panel with Polish first if it was not done. I did swirl haze remover mostly over the scratch spot but did go a few inches left and right of it. So your saying fine polish will take out that dark spot maybe? Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted August 27, 2021 Share Posted August 27, 2021 On 8/24/2021 at 9:02 AM, gred1987 said: I used the porter cable random orbital machine. I wouldn't think that you could have burn through with the PC. Link to comment Share on other sites More sharing options...
0 07stanggt Posted August 31, 2021 Share Posted August 31, 2021 You wont burn through that with a Porter cable. Does it feel rough or not as smooth as the paint around it? Link to comment Share on other sites More sharing options...
gred1987
