RobD Posted October 25, 2021 Share Posted October 25, 2021 Hello, I made a small resin and live edge wood table top and finished it a wax oil called Osmo Polyx, it will cure hard after a couple weeks. I know some ceramic coatings will work on these table tops as an extra protectant. Will Adam's graphene coating work on it to? If so, I would try it out as the protection from water and spills as well as scratch resistance would be a great addition.. Thanks Rob Link to comment Share on other sites More sharing options...
TheWolf Posted November 2, 2021 Share Posted November 2, 2021 On 10/24/2021 at 7:44 PM, RobD said: Hello, I made a small resin and live edge wood table top and finished it a wax oil called Osmo Polyx, it will cure hard after a couple weeks. I know some ceramic coatings will work on these table tops as an extra protectant. Will Adam's graphene coating work on it to? If so, I would try it out as the protection from water and spills as well as scratch resistance would be a great addition.. Thanks Rob No, a ceramic coating should not be applied over a wax oil. The ceramic will not bond with the wax, and it may have a negative reaction to it. Not worth risking messing up you hard work on the table top. Link to comment Share on other sites More sharing options...
jagWood Posted March 4, 2022 Share Posted March 4, 2022 Seems like this guy did exactly that and looks great!!! Link to comment Share on other sites More sharing options...
