TWW Posted February 7, 2022 Share Posted February 7, 2022 I try to do 3Ph car wash because I heard that is most strong & safe car wash method. 3Ph car wash is 1) Wash the car with high pressure water, and spray alkaline chemical for pre-wash. 2) After wait for minutes, rinse the chemical and cover the car with acid foam. 3) After wait for minutes, rinse the foam and wash with Ph-neutral shampoo. I already has car shampoo and acid foam, but I can't find alkaline pre-wash chemical. I has Adam's APC, but I don't have Ph level tester so I don't know it's Ph level. Is Adam's APC is Alkaline? Or you know any alkaline pre-wash chemical? Link to comment Share on other sites More sharing options...
0 falcaineer Posted February 7, 2022 Share Posted February 7, 2022 Washing with chemicals other than pH neutral can adversely affect the protection you have on your car, potentially removing or degrading it. Strip Wash is the only non-pH neutral soap offered by Adam's for that reason, and Adam's espouses a different approach than what you may do now. Here's more about most of Adam's car shampoos and why they are made the way they are. Link to comment Share on other sites More sharing options...
0 TWW Posted February 14, 2022 Author Share Posted February 14, 2022 On 2/7/2022 at 4:03 PM, falcaineer said: Washing with chemicals other than pH neutral can adversely affect the protection you have on your car, potentially removing or degrading it. Strip Wash is the only non-pH neutral soap offered by Adam's for that reason, and Adam's espouses a different approach than what you may do now. Here's more about most of Adam's car shampoos and why they are made the way they are. So It mean APC is PH-neutral? And also, sometimes we need deep clean for waterspot, lime, and cement, and we need to remove them in limited time, we can use Acid formula. However, I agree for this video for normal car wash with coated car. Link to comment Share on other sites More sharing options...
TWW
3Ph car wash is
2 answers to this question
