Rick H Posted March 21, 2022 Share Posted March 21, 2022 Is your wheel cleaner save on ceramic coated wheels? Link to comment Share on other sites More sharing options...
0 falcaineer Posted March 21, 2022 Share Posted March 21, 2022 Yes, but you may find you will not need it as much or as often. Ceramic coating generally makes surfaces easier to clean so soap and water might be all you need. Norton 1 Link to comment Share on other sites More sharing options...
0 Norton Posted March 21, 2022 Share Posted March 21, 2022 6 hours ago, falcaineer said: Yes, but you may find you will not need it as much or as often. Ceramic coating generally makes surfaces easier to clean so soap and water might be all you need. My wheels and brake calipers, all of which are coated, usually clean-up nicely with whatever I'm using to wash the entire car (i.e., shampoo). Link to comment Share on other sites More sharing options...
0 Rick H Posted March 21, 2022 Author Share Posted March 21, 2022 I normally use Adam's car shampoo or ultra foam shampoo, sounds like these products should work fine my wheels. Norton 1 Link to comment Share on other sites More sharing options...
0 RayS Posted March 21, 2022 Share Posted March 21, 2022 Steve got me thinking about the last time I used anything other than shampoo on a coated wheel, so I had to pull my book and look. It was February 2021 on the daughters Jag and even then it was Eco Wheel Cleaner. It was right after that when we changed the pads to ceramic and never had to do so again. Norton 1 Link to comment Share on other sites More sharing options...
Rick H
4 answers to this question
