ArcticBlueSS Posted May 9, 2022 Share Posted May 9, 2022 My Camaro has hood vents. I have soap stains/residue on the liner. I have tried a soft brush and water and just a wet towel with no luck. Does anyone have any success stories? TIA Link to comment Share on other sites More sharing options...
0 Junior Posted May 9, 2022 Share Posted May 9, 2022 Do you have pics? Have you tried using a pressure washer with a wide fan? Even going to the spray and wash and use the wand there? You might give that a shot. Link to comment Share on other sites More sharing options...
0 ArcticBlueSS Posted May 9, 2022 Author Share Posted May 9, 2022 (edited) I was hoping not to go that route. It seems like that may damage it. The liner is like insulation. Edited May 10, 2022 by ArcticBlueSS Link to comment Share on other sites More sharing options...
0 Rich Posted May 10, 2022 Share Posted May 10, 2022 Can you pop it off easily? If you can get it off, you could scrub it better with some soap, a brush, and a hose. Link to comment Share on other sites More sharing options...
0 ArcticBlueSS Posted May 10, 2022 Author Share Posted May 10, 2022 8 hours ago, Rich said: Can you pop it off easily? If you can get it off, you could scrub it better with some soap, a brush, and a hose. I may have to try that to see if it works. The funny part is that is what is causing the problem, soap. Thanks for your help. Link to comment Share on other sites More sharing options...
0 Rich Posted May 11, 2022 Share Posted May 11, 2022 12 hours ago, ArcticBlueSS said: I may have to try that to see if it works. The funny part is that is what is causing the problem, soap. Thanks for your help. Try some diluted APC. Link to comment Share on other sites More sharing options...
ArcticBlueSS
5 answers to this question
