Trap Posted May 24, 2022 Share Posted May 24, 2022 I am a little confused about claying a Graphene Coated vehicle,. I like the idea of it, just always heard that it was not good for the Coating. I watched this Adam's video and they day all is good. https://www.amazon.ca/WeatherTech-PetRamp-High-Traction-Foldable-Ramp/dp/B07JLRF5ZW?th=1 I would definitely only clay after using the foam cannon to apply that thick layer of soap as a lubricant. Sounds like I should have no problem, but want to see what other think. Link to comment Share on other sites More sharing options...
0 RayS Posted May 24, 2022 Share Posted May 24, 2022 Hi Al, I have partially clayed a coated vehicle a couple of times. In both cases it was for doing an area, not the whole vehicle, and I used the Fine Grade Clay. For the lube, I used CS3 and it seemed to work without any problems at all. Once was on a vehicle with some tree sap and other had some black specs on the hood and fender that came right off with clay, but didn't come off during a regular wash. Other than those two times, I have not found a reason to use clay on a coated vehicle - at least not yet. Link to comment Share on other sites More sharing options...
0 falcaineer Posted May 25, 2022 Share Posted May 25, 2022 Just like on a non-coated car you could always try the baggie test. If needed, usually the Fine Grade is usually sufficient for coated cars and is what I'd recommend. Use a lot of lubricant like Graphene Detail Spray and you should be good. Link to comment Share on other sites More sharing options...
0 The Guz Posted May 25, 2022 Share Posted May 25, 2022 The potential to marr is there regardless of the grade level of clay. I have seen it and experienced it regardless of the coating used. Link to comment Share on other sites More sharing options...
Trap
3 answers to this question
