Compound and polishing question. User error?
Loneranger
 Share
So today i was polishing my truck. 21 ford ranger black shadow. Well I started working on my door and I noticed when I was done and wiped away the compound it was full of hazy, swirly type marks all over it. I was using the adams blue compound and blue pad with swirl killer. Maybe speed was at 4 or 5. Then I went to the polish at speed 5 and had to work the hell out of it for awhile to get it looking good. Is this a result of user error? May pass are very well cleaned so I don’t know. Also one last question. I notice doing my upper front bumper and grooves/indents on doors the polisher seems like it doesn’t want to spin. Any technique for that? Thanks in advance…
3 answers to this question
If your paint is on the soft side the Blue Compound & Blue pad will leave haze. Next time start with White polish & pad and see what that does.
This is why you always want to do a test spot.
With experience you can mix pads & products to achieve better results with less work.
8 hours ago, Loneranger said:
Really? Like using the compound on white pad, etc? I know the hand polish and hand scratch and swirl remover do Jack by hand
In theory, yes. Something like Polish on a red pad to finish B pillars, or using both Polish and Compound on a blue foam pad for a "one step" process. Ultimately, it really depends on the car.
Hand Polish is more of a chemical cleaner. Scratch and Swirl Remover with the orange Hex Grip will work, but if the paint is on the harder side it could take some effort.
Answer this question...
 Share
