I have a 2022 Camaro with the black hood wrap. I never liked the wrap so I removed it. Unfortunately, It had some type of glue laid down on the hood. I researched this and found this to be a normal occurrence when others remove their hood wrap. However, most people found a couple of round sport of the glue. I found a couple of round spots along with a large percentage of my hood being smeared with the glue.
The most recommended solution I found through research was to use Goo Gone. This will remove some of the glue but where its heavy it doesn't seem to work that well. I have also clayed it and polished it. The polish does remove some of the glue but it will take me weeks of hand polishing to remove it and I'm not sure this is the preferred method of removal.
My questions are below:
Is polishing the correct way to remove this glue?
If polishing is the way to go should I purchase one of the electric polishers?
If I polish the glue off do I run the risk of cutting off too much of the clear coat surrounding the glue?
Will Goo Gone hurt the paint if I leave it on there for a few hours to try and cut through some of the glue?
Are there any other suggestions as how best to go about this?
mpride63
Thanks in advance for any help you can offer.
11 answers to this question
