DanAyo Posted February 11, 2023 Share Posted February 11, 2023 (edited) First time applying any Ceramic Coating to my car. I tried an initial application to the trunk lid. Applied in a cross hatch pattern. Turned off lights and used the UV Light. I can clearly see cross hatch patterns on the lid. Is this correct or do I need to change my application technique? Thanks in Advance, Dan Ayo Edited February 11, 2023 by DanAyo Mis-spell Link to comment Share on other sites More sharing options...
falcaineer Posted February 12, 2023 Share Posted February 12, 2023 As long as the coverage is complete and even, you're fine! Welcome to the forums!! Link to comment Share on other sites More sharing options...
The Guz Posted February 12, 2023 Share Posted February 12, 2023 Once the coating cures you will not see them. As stated as long as you got even coverage that is what matters. Link to comment Share on other sites More sharing options...
DanAyo Posted February 12, 2023 Author Share Posted February 12, 2023 I discovered that when waiting too long to rub the coating down, the coating would set. Once I started the rub down more quickly, the product was more evenly distributed (by buffing) and no more cross hatch patterns. The initial process of applying the coating was intimidating, but in practice it was a breeze. I found the coating to be very forgiving. Thanks for the replies, Dan Ayo Link to comment Share on other sites More sharing options...
falcaineer Posted February 12, 2023 Share Posted February 12, 2023 There is a fine line between when it's too soon and when it's too late. The surface should be slightly tacky, not slick. Wait too long though, and it'll be a shoulder workout for sure! Link to comment Share on other sites More sharing options...
