RandyL Posted June 1, 2023 Share Posted June 1, 2023 Can you put a second coat of Graphene ceramic coating 1 day after 1st coat? Is there any benefit? Link to comment Share on other sites More sharing options...
0 falcaineer Posted June 1, 2023 Share Posted June 1, 2023 Assuming proper prep and a full, even application, one layer is sufficient. With ceramic coatings, the law of diminishing returns applies - adding 2+ layers does not equate to 2x+ protection. Use the UV light to make sure you did a full application and you'll be good. That said, if you still decide to apply 2 layers, wait 1-2 hours in between layers max. The second layer will be easier to remove because the bottom layer will essentially reject much of the layer above it. Link to comment Share on other sites More sharing options...
0 The Guz Posted June 1, 2023 Share Posted June 1, 2023 One layer is good enough as long as you got even coverage. The second layer would be more for even coverage than additional durability. Link to comment Share on other sites More sharing options...
RandyL
2 answers to this question
