harryshummer Posted April 22, 2009 Share Posted April 22, 2009 Hello, I was wondering if anyone can help me make my engine compartment look brand new, I did watch one of adams video's and it wasn't real thourough. I understand cleaning it with APC and hosing it down after brushing then adding In and Out spray. But can anyone give a more detailed understanding of cleaning this part???? Here is a pic of my engine bay any input would help Quote Link to comment Share on other sites More sharing options...
harryshummer Posted April 22, 2009 Author Share Posted April 22, 2009 I show this vehicle at shows and this is the part I need help looking better. I also see that In and Out Spray is discontiued is there anything else to use??? what woks best?? Quote Link to comment Share on other sites More sharing options...
Huckleberry Posted April 22, 2009 Share Posted April 22, 2009 I use a pump sprayer with hotwater and apc cleaner added. I spray everthing down. Let it sit for a little while. In the south a little while is 10-15 mins.:glasses:I'll then get some small bushes and some rags and go to town wiping everything down. Then I wash everything off with fresh hotwater and then dry with compressed air. But I will tell you this, it is easier to keep the engine clean than it is to clean it. I hope this helps, also for the new look VRT is the next best thing to the In & Out spray. Quote Link to comment Share on other sites More sharing options...
Cyclone Posted April 23, 2009 Share Posted April 23, 2009 I use a pump sprayer with hotwater and apc cleaner added. I spray everthing down. Let it sit for a little while. In the south a little while is 10-15 mins.:glasses:I'll then get some small bushes and some rags and go to town wiping everything down. Then I wash everything off with fresh hotwater and then dry with compressed air. But I will tell you this, it is easier to keep the engine clean than it is to clean it. I hope this helps, also for the new look VRT is the next best thing to the In & Out spray. And on the VRT remark, you can mix some VRT with water and make a spray out of it. It does not work as good as the In&Out but it helps in the hard to reach areas Quote Link to comment Share on other sites More sharing options...
Bill-V8V Posted April 23, 2009 Share Posted April 23, 2009 But I will tell you this, it is easier to keep the engine clean than it is to clean it. :iagree::iagree: Quote Link to comment Share on other sites More sharing options...
