dennyb Posted April 27, 2009 Share Posted April 27, 2009 Whats the best way to wash and clean micro fiber towels, m/f polishing cloths,and machine pads,with household products? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
0 Cyclone Posted April 27, 2009 Share Posted April 27, 2009 Refer to this thread http://adamsforums.com/forums/showthread.php?t=1607&highlight=clean Quote Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted April 27, 2009 Share Posted April 27, 2009 This sticky is better. Everything is in one post. Quote Link to comment Share on other sites More sharing options...
0 dennyb Posted April 28, 2009 Author Share Posted April 28, 2009 Thanks guys for the info on the m/f towels,what about, how do you clean the machine pads? Quote Link to comment Share on other sites More sharing options...
0 Baron_Von_Awesome Posted April 28, 2009 Share Posted April 28, 2009 Thanks guys for the info on the m/f towels,what about, how do you clean the machine pads? May sound a bit silly, but I'll take the chance: Spray the pad with APC, let it sit for about 2 minutes, saturate with warm water, agitate with a stiff bristled tooth brush, rinse, repeat until the water dripping off the pad is clear. Don't scrunch or fold the pads in any way, as doing so will break the adhesive bond between the pad and the hook and loop backing. Quote Link to comment Share on other sites More sharing options...
0 Junkman2008 Posted April 28, 2009 Share Posted April 28, 2009 I spray mine down with APC and then let them soak in the Grit Guard buckets with a little Car Wash. Afterward, you can scrub 2 pads together and they'll clean each other at the same time. Quote Link to comment Share on other sites More sharing options...
0 jjwvette Posted April 28, 2009 Share Posted April 28, 2009 I spray mine down with APC and then let them soak in the Grit Guard buckets with a little Car Wash. Afterward, you can scrub 2 pads together and they'll clean each other at the same time. I like that method:thumbsup: Quote Link to comment Share on other sites More sharing options...
0 dennyb Posted April 29, 2009 Author Share Posted April 29, 2009 Great information guys Thanks Quote Link to comment Share on other sites More sharing options...
dennyb
