livingwater Posted May 3, 2009 Share Posted May 3, 2009 I was planning on storing my Adams products in my office above my garage. I keep the air conditioning and/or heat off unless I am in the office. Question: Will the summer heat ruin the Adams polish, wax, VRT, etc? What is the temperature tolerances the the product should be kept within? Example: 40 to 90°F Quote Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted May 3, 2009 Share Posted May 3, 2009 Your example is a good range, 50 to 80 would be even better Ideally you'd like to keep them around 70 all the time but as long as they don't freeze or boil you should be good to go :D:D During the summer my garage stays kind of cool so I keep them down there but I have a few shelves in the family room to put them on during the winter Quote Link to comment Share on other sites More sharing options...
0 Kwhite Posted May 3, 2009 Share Posted May 3, 2009 hmmm good point, im guessing that it wouldnt be a good idea t keep my adams products in the garage this summer out here in AZ? or do you think they will be okay. most it gets in there as long as it is kept shut is about 95-100 tops... Quote Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted May 3, 2009 Share Posted May 3, 2009 If it gets 95 to 100 I would bring them indoors, that is HOT !!!!!! Quote Link to comment Share on other sites More sharing options...
0 11chevz71 Posted May 3, 2009 Share Posted May 3, 2009 hmmm good point, im guessing that it wouldnt be a good idea t keep my adams products in the garage this summer out here in AZ? or do you think they will be okay. most it gets in there as long as it is kept shut is about 95-100 tops... Yeah in my eyes that is pushing the limit and do not know the real specs on the materials. Quote Link to comment Share on other sites More sharing options...
0 Loud Pedal Posted May 4, 2009 Share Posted May 4, 2009 I keep all my products in the climate controlled confines of my pantry And I'm not sure where the thread is that Adam recommends keeping them at a temp. of about 45 to 85 degrees. Quote Link to comment Share on other sites More sharing options...
0 Rich Posted May 4, 2009 Share Posted May 4, 2009 Reccommended temps are no lower than 45* and no higher than 85*. Quote Link to comment Share on other sites More sharing options...
0 Team Adam's Posted May 4, 2009 Share Posted May 4, 2009 If it gets 95 to 100 I would bring them indoors, that is HOT !!!!!! pfff... I've detailed in my garage mid august with the temp pushing 105*... just makes you work quicker Quote Link to comment Share on other sites More sharing options...
0 Chewy Posted May 4, 2009 Share Posted May 4, 2009 You put your Adams products in the family room? Mine stay in the basement except for some DS which I use regularly. Chris Quote Link to comment Share on other sites More sharing options...
0 jjwvette Posted May 5, 2009 Share Posted May 5, 2009 I'll put this one in the memory bank Quote Link to comment Share on other sites More sharing options...
0 Adam Posted May 5, 2009 Share Posted May 5, 2009 Reccommended temps are no lower than 45* and no higher than 85*. Thanks Rich, and all chemicals despise temperature changes, especially when they are below 45 or above 85. Well said, and products that have experienced temps above or below that range can separate, get clumpy, or otherwise expire long before they would if stored in the suggested temp range. Quote Link to comment Share on other sites More sharing options...
livingwater
Question:
Example: 40 to 90°F
10 answers to this question
