Chewy Posted May 8, 2009 Share Posted May 8, 2009 Hey all, Well I just ordered the Adams carpet and upholstery cleaner to see how it works on my issue. I also ordered the new brush to try. What are ya'll using to get rid of it? It's a hard calcium like build up that is almost bullet proof. It comes from a long hard winter in the Midwest and on black carpet, it looks like poop! My new (to me) Legacy GT has some that the PO tried to remove with no success. Cheers, Chris Link to comment Share on other sites More sharing options...
0 70'sChevyGirl Posted May 8, 2009 Share Posted May 8, 2009 I used the Carpet Shampoo on my Black carpet in the Charger recently. It looks brand new after a long winter of tracking salt into my car. Link to comment Share on other sites More sharing options...
0 Chewy Posted May 8, 2009 Author Share Posted May 8, 2009 Did you have those huge deposits stuck to the carpet? It happens around the gas pedal mostly. Drips off and onto the carpet. Chris Link to comment Share on other sites More sharing options...
0 Rich Posted May 8, 2009 Share Posted May 8, 2009 I use a very stiff bristled brush and brush it really good and vacuum it off. Then I use the Carpet and Uphostery cleaner diluted and clean it. Then I brush and vacuum again after it dries. Once you get it clean, get some of the clear floor mats or even the harder rubber ones. Saves the carpet big time. Link to comment Share on other sites More sharing options...
0 70'sChevyGirl Posted May 8, 2009 Share Posted May 8, 2009 Did you have those huge deposits stuck to the carpet? It happens around the gas pedal mostly. Drips off and onto the carpet. Chris Yes. Link to comment Share on other sites More sharing options...
0 Chewy Posted May 8, 2009 Author Share Posted May 8, 2009 Once you get it clean, get some of the clear floor mats or even the harder rubber ones. Saves the carpet big time. I have 3 set of mats in my G8 and a very nice set of Subaru mats in the Legacy and it still happens. I think it's inevitable. Thanks for your help both of you. I have the brush and cleaner coming. Why dilute it? Link to comment Share on other sites More sharing options...
0 Rich Posted May 8, 2009 Share Posted May 8, 2009 The Carpet and Upholstery Cleaner is extremely powerful full strength. I dilute mine 25% water/75% cleaner. If you're going to use it full strength, do a test spot first someplace you won't see it if it takes the color out of the carpet. Link to comment Share on other sites More sharing options...
0 70'sChevyGirl Posted May 8, 2009 Share Posted May 8, 2009 I used it in my Steam Cleaner which dilutes the shampoo. How much? I have no clue. Link to comment Share on other sites More sharing options...
0 Baron_Von_Awesome Posted May 8, 2009 Share Posted May 8, 2009 The upholstery cleaner should do the trick. If not, Home Depot sells a product called Folex that really works wonders on hard to remove spots & stains. Link to comment Share on other sites More sharing options...
0 jjwvette Posted May 8, 2009 Share Posted May 8, 2009 I use stream cleaner also and have no trouble with the salt on carpets:) Good luck....don't you just love winter Link to comment Share on other sites More sharing options...
0 Chewy Posted May 8, 2009 Author Share Posted May 8, 2009 I have a hoover hand held cleaner but getting it into the corner will be VERY difficult so I will try the new brush and some diluted cleaner on it. Thanks, Chris Link to comment Share on other sites More sharing options...
Chewy
Hey all,
Cheers,
Chris
10 answers to this question
