Marylander Posted May 10, 2009 Share Posted May 10, 2009 Anyone have any insight as to whether GWC is safe on things like plastic grills and in breaking up the heavy buildup of crap in door jams and inside trunk edges? And what about using it to clean an engine? Anyone tried that yet? Rich Quote Link to comment Share on other sites More sharing options...
0 Cyclone Posted May 10, 2009 Share Posted May 10, 2009 I would assume it is safe on paint... My rims are black powder coat , the chrome lips are clear coated, I have not seen anything happen to them. Adam's GREEN Wheel Cleaner is a 100% water-based cleaner! It contains no no petroleum distillates, no acids, and no butyl of any kind. It is 100% safe for use on tires and all wheel finishes including polished aluminum and clear coats. With light agitation, Adam's GREEN Wheel Cleaner quickly and safely removes all dirt, road oils, and brake dust without harming you wheels, the environment or you!. By saying that it is safe on clear coat pretty much sums it up that it should work great on your jambs... As far as engine plastics and such, If it is safe to use on rubber tires, I don't see how it could harm plastics Quote Link to comment Share on other sites More sharing options...
0 Sundog Detailing Posted May 11, 2009 Share Posted May 11, 2009 I have even used it successfully on carpet and upholstery, it works well on stubborn stains. Quote Link to comment Share on other sites More sharing options...
0 Marylander Posted May 11, 2009 Author Share Posted May 11, 2009 Cool. I just used it to clean my pads, too. The stuff does everything! Quote Link to comment Share on other sites More sharing options...
0 Superdutytd Posted May 11, 2009 Share Posted May 11, 2009 It really does. Adam should sell it by the 5 gallon. Quote Link to comment Share on other sites More sharing options...
0 Devin04 Posted May 11, 2009 Share Posted May 11, 2009 It's replaced my APC. I think that it might replace APC in general. Quote Link to comment Share on other sites More sharing options...
0 WaxOnWaxOff Posted May 11, 2009 Share Posted May 11, 2009 Adam- Can I use it to clean my kitchen?! Quote Link to comment Share on other sites More sharing options...
0 Loud Pedal Posted May 11, 2009 Share Posted May 11, 2009 I love the GWC, but I cleaned my stainless BBQ grill with it and I have 3 panels that are painted and it ate the paint up bad. So I'm just going to order those panels and replace them with a lesson learned. lol Quote Link to comment Share on other sites More sharing options...
0 dhh_93 Posted May 11, 2009 Share Posted May 11, 2009 works great for getting bugs off front bumper. hardly and scrubbing required. Quote Link to comment Share on other sites More sharing options...
0 brickbrad Posted June 11, 2009 Share Posted June 11, 2009 I know the GWC is safe on the paint/clear coat, but does it remove the wax if used to remove bug guts such as on the front bumper? Quote Link to comment Share on other sites More sharing options...
0 bigred vette Posted June 11, 2009 Share Posted June 11, 2009 I know the GWC is safe on the paint/clear coat, but does it remove the wax if used to remove bug guts such as on the front bumper? Yes, if it doesnt totally remove it the first time it will severly shorten the lifespan. All though its safe on most finishes it still is a cleaner and was designed to cut through dirt and grime. BTW nice avatar, giggity! giggity! giggity! giggity! Quote Link to comment Share on other sites More sharing options...
0 brickbrad Posted June 11, 2009 Share Posted June 11, 2009 Yes, if it doesnt totally remove it the first time it will severly shorten the lifespan. All though its safe on most finishes it still is a cleaner and was designed to cut through dirt and grime. BTW nice avatar, giggity! giggity! giggity! giggity! Giggity Giggity Alright! Glad you enjoy it. Can the GWC replace the APC in cleaning the engine and wiping wax residue off plastic moldings? Quote Link to comment Share on other sites More sharing options...
0 bigred vette Posted June 11, 2009 Share Posted June 11, 2009 Giggity Giggity Alright! Glad you enjoy it. Can the GWC replace the APC in cleaning the engine and wiping wax residue off plastic moldings? Yep!:2thumbs: Quote Link to comment Share on other sites More sharing options...
0 GerryC Posted June 11, 2009 Share Posted June 11, 2009 I used it to clean my daily driver's engine that had never been cleaned before, much easier on tough grime than APC Quote Link to comment Share on other sites More sharing options...
0 Superdutytd Posted June 11, 2009 Share Posted June 11, 2009 GWC works great! Quote Link to comment Share on other sites More sharing options...
0 Loud Pedal Posted June 11, 2009 Share Posted June 11, 2009 I know the GWC is safe on the paint/clear coat, but does it remove the wax if used to remove bug guts such as on the front bumper? It will remove any protection you have on the car so make sure you put another coat on afterwards. Quote Link to comment Share on other sites More sharing options...
0 jjwvette Posted June 11, 2009 Share Posted June 11, 2009 Never had a problem Quote Link to comment Share on other sites More sharing options...
0 Chewy Posted June 11, 2009 Share Posted June 11, 2009 Giggity Giggity Alright! Glad you enjoy it. Can the GWC replace the APC in cleaning the engine and wiping wax residue off plastic moldings? Been there done it... It's a great engine cleaner IMO... Try using the power stick for those hard to reach areas under the hood too... Just make sure there's no wires to get wrapped around it... Quote Link to comment Share on other sites More sharing options...
Marylander
Rich
17 answers to this question
