The Porter-Cable 7424 Operator's Manual
Junkman2008
 Share
You can download the PC-7424 owner's manual by clicking this link. It is in the PDF format, thus you must have the free Adobe Reader installed in order to view it. It will open within your browser window after you click the link.
If you actually want to save the manual on your computer, right-click the link and choose "save link as", then choose a location on your computer to save it.
Most folks looking for the manual are looking for information on what size extension cord to use with the PC-7424. I made this chart which describes the recommended extension cord specifications, based on data found in the operator's manual.
The manual specifically states that an undersized (extension) cord will cause a drop in line voltage resulting in loss of power and overheating! Remember, gauge and ampere are both equally important so you must ensure that your extension cord meets both specifications!
If you are experiencing a problem with your usint getting hot or turning off for some unknown reason, this is most likely the problem. Ensure that the extension cable you use meets both the gauge and ampere that is recommended by the manufacturer! :thumbsup:
The Junkman
9 answers to this question
Answer this question...
 Share
