Shimy86 Posted May 20, 2009 Share Posted May 20, 2009 When I apply the MSW I set the PC on 3 and then just put it on black pad and spread it out, or do you work it over a panel for awhile?? I also let it dry for a couple hours? Its on black Link to comment Share on other sites More sharing options...
0 Team Adam's Posted May 20, 2009 Share Posted May 20, 2009 Its not necessary to "work" the product when you use the black pad... its simply to spread the product evenly over the surface. Sealants and waxes are not like polishes where they need to be broken down to do their magic. As for dry time, a couple of hours would be excessive. Typically I allow 15-20 minutes for MSW to cure. Of course this varies based on ambient temp, humidity, and how thick of a coat you put on (very thin coats are ideal) Link to comment Share on other sites More sharing options...
0 Superdutytd Posted May 20, 2009 Share Posted May 20, 2009 I usually set mine to 4 (I like to move fast ) and do a couple of passes over each fender back and forth and up and down to make sure the product is nice and evenly spread out. I don't know if thats what everyone else says but thats what I do! Link to comment Share on other sites More sharing options...
0 GerryC Posted May 20, 2009 Share Posted May 20, 2009 Dylan is correct, with the superwax you do not need to "work it in" as you would with a polish. Therefore using a lower setting on the PC such as 3-4 will work, and you can use a quicker pace when going over the car, as you are only laying down a thin coat of the product. 20 minutes is a good amount of time to let it dry, unless it's really hot and/or humid I'd wait a little more. If possible, do this in the shade on a relatively cooler day. The only gripe I have about MSW and the black pad is that when I ordered them, it did not come with everything pictured: :jester: Link to comment Share on other sites More sharing options...
0 Superdutytd Posted May 21, 2009 Share Posted May 21, 2009 Yea I didn't get a gt500 either.... Link to comment Share on other sites More sharing options...
0 BrianT Posted May 21, 2009 Share Posted May 21, 2009 Yea I didn't get a gt500 either.... I don't see a car, or the PC... I must not be looking at the picture right. Link to comment Share on other sites More sharing options...
0 GerryC Posted May 21, 2009 Share Posted May 21, 2009 Yea I didn't get a gt500 either.... It's in the background if you look real close Link to comment Share on other sites More sharing options...
0 jjwvette Posted May 25, 2009 Share Posted May 25, 2009 Dylan is correct, with the superwax you do not need to "work it in" as you would with a polish. Therefore using a lower setting on the PC such as 3-4 will work, and you can use a quicker pace when going over the car, as you are only laying down a thin coat of the product. 20 minutes is a good amount of time to let it dry, unless it's really hot and/or humid I'd wait a little more. If possible, do this in the shade on a relatively cooler day. The only gripe I have about MSW and the black pad is that when I ordered them, it did not come with everything pictured: :jester: I didn't get the babe in the blue jeans ....... Link to comment Share on other sites More sharing options...
0 GerryC Posted May 25, 2009 Share Posted May 25, 2009 That was my main complaint Link to comment Share on other sites More sharing options...
0 11chevz71 Posted May 26, 2009 Share Posted May 26, 2009 That was my main complaint darnet thats why i was going to order it in the first place. Link to comment Share on other sites More sharing options...
Shimy86
9 answers to this question
