Foamy Gun
694doorbird
 Share
5 answers to this question
A garden spray, while similar in appearance to a foam gun, is a vastly different thing.
A garden sprayer is designed to mix a single chemical (fertilizer or whatever else) in a concentrated form with water and simply dispense it at a correctly metered rate so as to not over or under treat your grass/plants/etc.
A foam gun balances the amount of water, soap, and air to generate an effective mixture of high lubricity foam. Additionally the gun sold by Adams allows you to meter up or down the amount of soap in the mixture with the turn of a dial to treat different surfaces with different levels of foam.
Answer this question...
 Share
