Let me say this as a first time Adam's customer. I could not believe how EASY the Adam's Car Care Products are to use. Every product that I used today went on easier than Adam said in his DVD, especially if you follow what is in the DVD you can not even mess up. These products are foolproof. It was a very long 12 hours for me today.
I did not have many scratches on the car but my problem I had was waterspots (as you can see below).
I started out with the orange pad and the Swirl Haze Remover (SHR). After the first pass I was not satisfied with the results so I did what Adam said do it over again, this pass I used "4". Second time I went slower and used "6" on the Porter-Cable (PC), then I looked again. Finally after the third pass I was impressed. I used "4" on the third pass.
Then with the white pad and the Fine Machine Polish (FNP). I decided to go slow with it and used "3" and "4" on the PC. If going slow helped me before it should on this step. After the first time I was not impressed so I did it again.
Last Step I used the black pad and the Machine Super Wax (MSW). I used the "3" and "4" on the PC for this. Again I went slow. I had to do it twice.
I learned several things doing this today. Main rule is watching your speed (moving it across your vehicle and the RPM of the PC).
Here is my before pic
Here are two after pics:
Thank You goes to several members here and especially to Adam, Rob, and Steve.
DieselDude
Edited by DieselDudeLink to comment
31 answers to this question
