DenaliDan Posted September 13, 2009 Share Posted September 13, 2009 So I'm in the 12 hour waiting period after applying and buffing off a coat of Machine SuperWax. I had the idea of putting down a coat of BSG and wiping it off with the 12 hour buff. What do you all think? Any benefit? Quote Link to comment Share on other sites More sharing options...
0 6spdg37s Posted September 13, 2009 Share Posted September 13, 2009 ur car is probably going to blow up now cause the gases are all bottled in! lol jp jp idk sometimes in a hurry i havent waited 12 hours havent noticed any difference versus waiting the 12 hrs and doing it Quote Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted September 13, 2009 Share Posted September 13, 2009 Wait the 12 hours :2thumbs: Quote Link to comment Share on other sites More sharing options...
0 mikegeaney Posted September 13, 2009 Share Posted September 13, 2009 Having just used the MSW for the first time last weekend.....I'd say to wait as well. Once you make sure the residue is all off then go to town with the BSG. Quote Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted September 13, 2009 Share Posted September 13, 2009 Wait the 12 hours :2thumbs: Quote Link to comment Share on other sites More sharing options...
0 xlr8rvette Posted September 14, 2009 Share Posted September 14, 2009 (edited) If you don't want to wait the full 12 hours, you can wait 11 hours and 59 minutes. That will be okay Edited September 14, 2009 by xlr8rvette Quote Link to comment Share on other sites More sharing options...
0 IMADreamer Posted September 14, 2009 Share Posted September 14, 2009 are you seriously supposed to wait 12 hrs? Is that on the bottle? Man I'm luck if I wait an hour. Quote Link to comment Share on other sites More sharing options...
0 bigred vette Posted September 14, 2009 Share Posted September 14, 2009 are you seriously supposed to wait 12 hrs? Is that on the bottle? Man I'm luck if I wait an hour. Yes, its like letting paint cure. The MSW has to release gasses and they can leave an oily or smeared looking finish that can easily be wiped away. That smeared look will be trapped if you seal it before the 12 hours is up. Quote Link to comment Share on other sites More sharing options...
0 MitsukiGT Posted September 14, 2009 Share Posted September 14, 2009 When I came back after 12 hours (I waited m ore like 20 hrs) there was noticeable residue I had to wipe off. Quote Link to comment Share on other sites More sharing options...
0 JJ1o87 Posted September 14, 2009 Share Posted September 14, 2009 Yeah wait the 12 hours, I've only used MSW once or twice and had a little bit of residue the next day. Quote Link to comment Share on other sites More sharing options...
0 IMADreamer Posted September 14, 2009 Share Posted September 14, 2009 Yes, its like letting paint cure. The MSW has to release gasses and they can leave an oily or smeared looking finish that can easily be wiped away. That smeared look will be trapped if you seal it before the 12 hours is up. Oh you mean just if I am doing it after MSW? Quote Link to comment Share on other sites More sharing options...
0 jjwvette Posted September 15, 2009 Share Posted September 15, 2009 I didn't know you had to wait 12 hrs. :willy: Quote Link to comment Share on other sites More sharing options...
0 TR6speed Posted September 23, 2009 Share Posted September 23, 2009 I live in Florida and the humidity has an affect on the drying time, but I have never waited that long. In fact I normally remove it anywhere from 30 minutes to an hour after I applied it. Adam asked me on a post where I show a few pictures of my car after the application if I had any issues with a haze or residue when I removed it. I have never had an issue with it. I do not remove it by hand however. I use an old Adam trick, and use a plush microfiber towel and my pc. I lay the towel out fully opened on the surface then place the buffer on the towel almost in one corner and wrap the excess around the handle of the buffer. It will take a few towels, but it works great. I have heard that if you have residue still on the finish a quick wipe down with Adams Detail spray will take care of it. Quote Link to comment Share on other sites More sharing options...
0 GerryC Posted September 23, 2009 Share Posted September 23, 2009 (edited) I live in Florida and the humidity has an affect on the drying time, but I have never waited that long. In fact I normally remove it anywhere from 30 minutes to an hour after I applied it. Adam asked me on a post where I show a few pictures of my car after the application if I had any issues with a haze or residue when I removed it. I have never had an issue with it. I do not remove it by hand however. I use an old Adam trick, and use a plush microfiber towel and my pc. I lay the towel out fully opened on the surface then place the buffer on the towel almost in one corner and wrap the excess around the handle of the buffer. It will take a few towels, but it works great.I have heard that if you have residue still on the finish a quick wipe down with Adams Detail spray will take care of it. The 12 hours everyone is speaking of is not the cure/dry time for the wax before you wipe off the residue. 12 hours after wiping off the residue, you should re-wipe the surface of the car because the superwax has oils in it that make their way to the surface of the wax after it dries. These oils cause a hazy look on the paint. If you put a second coat of wax on before waiting for the oils to come up and wipe them off, you'll trap them between the 2 layers of wax and the haziness will remain. You are correct to let the wax cure for about half an hour in your climate, just be sure to go wipe down the car with an MF towel and a little bit of Detail Spray 12 hours later before putting on any more wax Edited September 23, 2009 by GerryC Quote Link to comment Share on other sites More sharing options...
DenaliDan
13 answers to this question
