Lifted the Suby
Sundog Detailing
 Share
This is just step one, I still have to get an alignment, larger tires are coming soon, and I have a trailing arm issue to work out but so far so good. This lift puts me 2" higher than stock and 5" higher than I was.
Before:
After:
Rally-X season starts in Oct so now I'm ready, and I'll be doing some offroading as well.
I used the suspension from an 05 Forester, there is a company that makes a 1" lift block kit but I wanted a little more. I have camber bolts in both front and rear so alignment will all good, the trailing arm issue affects caster but I know what I need to do to fix it, it's just a matter of fabbing up new mounts where it attaches to the chassis.
Okay, i was thinking that it sat like a forester now. How she handle the turns
Snow a bit deep in Alaska or...?
Last year at the first Rally-X the snow was mid thigh, so yeah it can get plenty deep, not a problem now though.
It turns fine, I still have the large front sway bar but removed the rear sway bar and sub-frame lock bolts to get the articulation
Reply to this topic...
 Share
