I was trying to help a neighbor restore their headlights (since I got my 4" kit today) they had some wierd yellow "coating" type stuff on it. I could feel it with my hand, but a drill on full speed will SHR and a yellow pad wasn't making this tuff budge.
I don't know if glass is the same properties of clear coat... Can you sand with 2000 and work your way back up to 2500 and then 3000 and then get the 3000 out with the yellow or orange like I saw junkman do on clear coat with 2500 > 3000> orange with SHR? Or once you sand glass is it perminantly ruined?
I also want to try the same on plexiglass, like on a motorcycle wind deflector. There isn't the wierd yellow stuff, but it is scratched up like someone rubbed it with a steel wool pad. There is a sticker that says don't use abraisives on it, but minor scratches can be removed, but I wasn't sure if that was just a legaly obligated warning type sticker and if you can "take layers" of a plexiglass off, or is there some kind of protective coating like a clear coat on them too?
nooner
Thanks.
8 answers to this question
