Quick question
jpu471
 Share
what is the size of the pc washer while changing my backing plate it fell off and disappeared also my pc is new yet when i turn it off there is a little binding "squeak" mice?
Do you mean the thin ceramic washer that came with the backing plate? That is 1" dia and 1/16" thick. If you mean the one that came with the PC, the wierd smaller dia thicker one. I was told that wasn't needed.
yes the one that came with the pc the one that aj said i'd go to pc h*** if i didn't use it:)
If you don't use the washer that comes with the PC, it makes it hard to tighten the back plate down AND remove the wrench. You can get it almost tight but it will eventually work its way loose and you'll end up striping something or digging into your paint with the PC's metal stud. Not a good scenario. Some back plates rub without that washer (I have a lot of different back plates). You really need to look for that washer. You may be able to replace it with one a little smaller in diameter than what comes attached to the yellow back plate. It should be the same thickness though.
Also, start using some punctuation in your post. It makes it much easier to read and old people like me will respond to your post. If I have to break out my Captain Crunch decoder ring just to figure out what you've posted, I won't bother to respond. Remember, this is a message board not text messaging. :thumbsup:
Answer this question...
 Share
