Mechanics: what can you tell from these plugs?
Marylander
 Share
My wife's 97 Honda got a CEL the other day. I borrowed an OBD scanner and got the code indicating a #3 cyl misfire. I pulled the plug and I thought it looked OK. Since the wires were from 2002 and the car probably hasn't had new plugs or wires since then, or about 60K miles, I decided to replace them.
Taking the old plugs and wires out I noticed that the #3 plug was more silver where as the other three were more golden/bronzed. And the #3 wire had a white-ish discoloration to it while the other three were more rubbery and just dirty.
Anyone have any idea why this might be? The car has 120K miles on it but seems to be running fine. There is also a slight knock that we can't seem to resolve, though I don't know if it's related.
Rich
The other 3 wires have oil residue on them. Probably from a distributor o-ring seepage or leak, or possibly a valve cover gasket or cam plug seeping oil. # 3 is just clean, probably positioned on the cap away from the oil leak source. oil will also make the wires feel more rubbery. # 3 is your normal wire.
Response #1 (from a guy who builds badass Honda engines for a hobby)
You can use a noid light to see if the injector is getting a signal.
You can use a multimeter to measure the resistance of the plug wire.
You can throw some fresh plugs in, reset the light, and see if the code comes back.
I would do a little more diag before spending $$ and throwing parts at it.
Response #2
Throw a timing light on the number 3 plug wire, rev it up, and if you see the timing light flicker out of sequence or the light quits flashing you will know it's spark related.
Response #3
Replace plugs and wires....
Response #4 (also a Honda guy, drag races a an Integra)
Those plugs and wires look terrible.
* Replace plugs and wires
* Reset ECU (pull the ecu fuse and back up fuse in engine compartment or pull battery cable off for a couple min)
* If CEL comes back, trying moving the injector to a different cylinder and see if the problem follows the injector.
Thanks for all the replies so far. I did change the plugs and wires and reset the CEL. Si far it seems to be running OK. I'm not too terribly worried about it as we're going to be selling the car soon, but I'm curious as to what's causing it. The funny thing is that the threaded part of the #3 plug was so much cleaner than the other 3, making me think that cylinder wasn't/isn't operating the same as the others.
Those plugs looked pretty good. May be running a bit rich but not bad enough to worry about. A good set of NGK's and good silicon wires will go a long way!
I always put a dab of anti-seize on my plugs threads and then use di-electric grease on the connections.
The car could have 120,000 miles on those plugs and wires, either way they look good (hard to tell sometimes about color with a picture than seeing them in person).
I do the same thing and have never had any problems with removing the plugs or plug wires. Especially if you ever have to remove them again.
Reply to this topic...
 Share
