IowaEmt1991 Posted January 27, 2010 Share Posted January 27, 2010 I am picking upmy first black car tomorrow. It swirled as i expected but ik how to fix that. My guestion is: i can see a pattern left by the buffer machine from the previous owner. Will the come out with a good SHR, Revive, and buttery detail? Thanks, Eric Link to comment Share on other sites More sharing options...
Chris@Adams Posted January 27, 2010 Share Posted January 27, 2010 Without seeing pics I can't say 100% However I would say that yes Orange pad & SHR will do the trick! Link to comment Share on other sites More sharing options...
IowaEmt1991 Posted January 27, 2010 Author Share Posted January 27, 2010 I dont have any pics as the car is in the shop getting new brakes. Im sure you know the pattern the buffer leaves behind in the polish before it is wiped off? Well that pattern can still be seen on the paint. Link to comment Share on other sites More sharing options...
BADRIDES Posted January 27, 2010 Share Posted January 27, 2010 Im sure you know the pattern the buffer leaves behind in the polish before it is wiped off? Well that pattern can still be seen on the paint.Had to fix one yesterday that another detail shop messed up. Link to comment Share on other sites More sharing options...
IowaEmt1991 Posted January 27, 2010 Author Share Posted January 27, 2010 can it be fixed? Link to comment Share on other sites More sharing options...
mc2hill Posted January 27, 2010 Share Posted January 27, 2010 Without seeing pics I can't say 100% However I would say that yes Orange pad & SHR will do the trick! I have used Orange pad and SHR to remove 2500 grit wet sanding marks, so you should be ok. Link to comment Share on other sites More sharing options...
IowaEmt1991 Posted January 27, 2010 Author Share Posted January 27, 2010 Okay great, They marks are not that bad, so it should be okay. Thanks for thelp. Link to comment Share on other sites More sharing options...
Chewy Posted January 28, 2010 Share Posted January 28, 2010 It'll take time but it's doable... Set aside a couple of days work to get it done. Chris Link to comment Share on other sites More sharing options...
Chris@Adams Posted January 28, 2010 Share Posted January 28, 2010 Patience is the key! Link to comment Share on other sites More sharing options...
IowaEmt1991
Thanks,
Eric
8 answers to this question
