Gulfstream
blackberrypilot
The plane has been sitting in the sun for 5 years... it really needs new paint which will cost plenty, probably $150k+
I'm not sure what I'll have to use to break this oxidation. Just washing it broke my back... I wish I would have taken pictures of the dirty wheel wells.
APC + VRT/Water (50/50) works well. :)
N59AJ. Hey AJ, I didn't know you had an airplane. That G2 is a little old. Time to upgrade!
The worst part of polishing an aircraft is doing the bottom of the wings. It's an arm killer. And the Gulfstream has a LOT of wing :pc:
Have fun with that one, Jeff. You at Lakefront or Armstrong?
Nah... Just flip it upside down... Heck it's a plane isn't it? :lolsmack:
I'm thinking if you can afford a Gulfstream then you can afford a 150,000 dollar paint job and you sure as heck fire can afford a buff job.
Keep us up to date!:)
Chris
Imagine a pallet of clay bars, a pallet of detail spray. What a huge job. Get a dozen guys with claybars, DS, and baggies and have at it.
If he puts an Adams finish on that plane at the quality you would a car, I wonder if it would slide through the air better, less drag? Sure would be shiny. Definitely an environment for MSW.:D
This plane is in horrible condition, so for a wash, polish, wax + brightwork the price is $6,500. The brightwork is worth $2,500 by itself.
There is no clearcoat, gel coat is gone. Paint is chipping in many areas, except the bottom portion of the wings.
The brightwork will require heavy duty compounds to cut the years of oxidation, so #7 with a high speed rotary is my only option there.
Oh and the plane is a G3, not a 2. :)
Soo if the gelcoat is gone what are you polishing? Just wondering.
Ok I am confused, boats have gelcoat and planes have paint right...? Gelcoat is a resin based pigment that is sprayed first in the mold. Airplanes are made of metal that is painted or a fabric over a wood frame, has gelcoat been used am I never heard of it?
Guess I didn't look close enough at the windscreen. Looked like a 2B with a hush kit. Good luck with it! You definitely have your work cut out for ya!
