The first time I used SHR with the PC, I got quite a bit of dusting. After going back and reading up on using SHR, I realized I was using too much product. By using less product, the dusting was dramatically reduced. However, I also found out something else that helps reduce dusting. By setting the PC to around 3,000 and spreading the product first before increasing the speed and applying pressure, the dusting was practically gone. If I went straight to a higher speed without spreading the product at a lower speed, there was more dusting involved. This may seem simple to some that spread their product at lower speeds first, but for those that start off high, I thought this would be good to know.
Sooners
8 answers to this question
