blackberrypilot Posted March 6, 2010 Share Posted March 6, 2010 Someone told me that BW and Americana does not stain trim, is this true? Quote Link to comment Share on other sites More sharing options...
0 GTO Guy Posted March 6, 2010 Share Posted March 6, 2010 yup! Quote Link to comment Share on other sites More sharing options...
0 Adam Posted March 6, 2010 Share Posted March 6, 2010 Jeff, it's certainly easy to remove any residue off the trim left by BW or Americana. HOWEVER: In our detailing system, I ALWAYS suggest using VRT on the trim before you ever start polishing, or waxing. That makes for zero, or nearly zero transfer to your trim. One more point, while we are at it: Older trim oxidizes, and becomes porous. Porous trim has a much higher potential of holding polish or wax residue. What I do: Use VRT before polish or wax. If a car has white residue on the trim, remove it with APC on a microfiber towel. Even the cheapest, bright-white residue from ultra-low grade wax comes off trim easily with our APC and a microfiber towel. Quote Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted March 6, 2010 Share Posted March 6, 2010 Jeff, it's certainly easy to remove any residue off the trim left by BW or Americana. HOWEVER: In our detailing system, I ALWAYS suggest using VRT on the trim before you ever start polishing, or waxing. That makes for zero, or nearly zero transfer to your trim. One more point, while we are at it: Older trim oxidizes, and becomes porous. Porous trim has a much higher potential of holding polish or wax residue. What I do: Use VRT before polish or wax. If a car has white residue on the trim, remove it with APC on a microfiber towel. Even the cheapest, bright-white residue from ultra-low grade wax comes off trim easily with our APC and a microfiber towel. Quote Link to comment Share on other sites More sharing options...
0 11chevz71 Posted March 6, 2010 Share Posted March 6, 2010 Quote Link to comment Share on other sites More sharing options...
0 blackberrypilot Posted March 6, 2010 Author Share Posted March 6, 2010 Thanks for the quick replies. Adam, keep up the great work! Your products are by far the easiest to work with and deliver extraordinary results. What I think you need now is a long term/weatherproof protectant for rubber/plastic pieces. Quote Link to comment Share on other sites More sharing options...
0 Darth_Emma Posted March 6, 2010 Share Posted March 6, 2010 Dang, and I just bought a roll of painter's tape today to stop the trim from getting polish/wax on it. I'll just use the VRT first. Quote Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted March 7, 2010 Share Posted March 7, 2010 Tape is great for when you are polishing but the VRT tip Adam mentioned is great for when just putting on a coat of wax Quote Link to comment Share on other sites More sharing options...
0 whiterp199 Posted March 7, 2010 Share Posted March 7, 2010 I never thought to do VRT first. I am going to try that tomorrow. Quote Link to comment Share on other sites More sharing options...
0 11chevz71 Posted March 9, 2010 Share Posted March 9, 2010 I never thought to do VRT first. I am going to try that tomorrow. Another nice thing about it is if you get it on the paint you are going to take it off with the wax. Quote Link to comment Share on other sites More sharing options...
blackberrypilot
9 answers to this question
