I read many posts describing how many pounds of pressure to be applied to the PC... but this is hard to judge... and practicing on a bathroom scale is really inaccurate.
I put a 1/2" black strip on the back of my backing pad... so I can see the rotation.
Now all I need to know is, how fast should the pad rotate?
Pressure is irrelevant... since depending upon the speed (which also affects torque)... the same amount of pressure will cause the pad to rotate at different speeds depending upon the speed setting of the PC.
Conversely... different amounts of pressure will be required to keep the pad spinning at the same rotation speed at different PC speed settings.
So... have you marked your backing pad?
.... and if so, what rotation speed should we be shooting for?
Brett LaCroix
9 answers to this question
