MburgWVDetailer Posted March 18, 2010 Share Posted March 18, 2010 I am making the switch from using mainly Mequiar's products to Adams. I purchased the Mequiar DA, the model number is G110 or something like that. I want to start using the Adam's pads, but will they fit? Link to comment Share on other sites More sharing options...
GXPaycheck Posted March 20, 2010 Share Posted March 20, 2010 I use the G110. Had to replace it once due to manufacturing defect but other than that it works the same as the PC. Backing pads just screw right on. I do like the handle better than the PC. Easier to keep a grip on the head. Link to comment Share on other sites More sharing options...
Junkman2008 Posted March 22, 2010 Share Posted March 22, 2010 Michael Stoops at Meguiars says: "The G100/G110a were rebranded Porter Cable 7424 machines. The G110 was our own design, and the G110v2 is our own serious upgrade to the G110." Have you ever taken one apart? The insides are the same as the PC's. I don't know what part they designed. Maybe they added the handle, but that's about it. Link to comment Share on other sites More sharing options...
Bunky Posted March 22, 2010 Share Posted March 22, 2010 Michael Stoops at Meguiars says: "The G100/G110a were rebranded Porter Cable 7424 machines. The G110 was our own design, and the G110v2 is our own serious upgrade to the G110." Link to comment Share on other sites More sharing options...
Junkman2008 Posted March 21, 2010 Share Posted March 21, 2010 Dude, Adam practically gives this stuff away at the shows! Link to comment Share on other sites More sharing options...
Chris@Adams Posted March 21, 2010 Share Posted March 21, 2010 I got it for 150 dollars along with the full line of the mirror glaze products and a finishing and foam pad. They had an early bird special at the show I got it at and I'm guessing they were trying to get rid of the G110 to make room for the G110v2. Can you get good deals for Adams products if you stop by their both at a show? Yes Show prices are better! Plus no shipping! That is the time to stock up. Link to comment Share on other sites More sharing options...
MburgWVDetailer Posted March 21, 2010 Author Share Posted March 21, 2010 I got it for 150 dollars along with the full line of the mirror glaze products and a finishing and foam pad. They had an early bird special at the show I got it at and I'm guessing they were trying to get rid of the G110 to make room for the G110v2. Can you get good deals for Adams products if you stop by their both at a show? Link to comment Share on other sites More sharing options...
GXPaycheck Posted March 21, 2010 Share Posted March 21, 2010 Plus I believe the G110 is made in some oriental place while the PC is made in the US of A! Link to comment Share on other sites More sharing options...
Bunky Posted March 20, 2010 Share Posted March 20, 2010 I would disagree since they are nothing but rebadged PC's. The G110 and the V2 come with a lifetime warranty when purchased at a Mirror Glaze distributorship but the price is stupid crazy. $250 each. The UDM is exactly the same as the PC-7424XP. I was referring to the original UDM 1.0. The UDM 2.0 is the same PC. I keep forgetting they did this... Link to comment Share on other sites More sharing options...
Nitelord Posted March 20, 2010 Share Posted March 20, 2010 Thank you.. Link to comment Share on other sites More sharing options...
Junkman2008 Posted March 20, 2010 Share Posted March 20, 2010 I guess I know the answer, but Can you remove the handle on the G110V2? I don't use it on the PC and have become used to handling it that way. Yes you can. It is held on by two screws. Link to comment Share on other sites More sharing options...
Nitelord Posted March 20, 2010 Share Posted March 20, 2010 I guess I know the answer, but Can you remove the handle on the G110V2? I don't use it on the PC and have become used to handling it that way. Link to comment Share on other sites More sharing options...
Junkman2008 Posted March 20, 2010 Share Posted March 20, 2010 The G110 was more powerful than the PC 7424 as measured in OPM's -- about the same as the UDM. It used all the backing plates, etc the PC did. However, it was short lived (2 yrs) and replaced with the G110V2 which is an all new design that rivals the PC XP and other DA polishers. Power-wise, both the G110 and the G110V2 are exactly the same. The G110 was 800 OPM's more powerful than the PC-7424. It was basically an early intro to the PC-7424XP. The G110V2 is nothing more than a PC-7424XP rebadged for Meguiar's (just as the G110 was). If you have either machine, it will work fine as I have used them extensively side by side and have not seen any noticeable difference. The Adam's pads will also fit fine or you could change the backing plate if you prefer. I would say no since Meg's comparison between the UDM and G110 are not the same based upon OPM's, noise level, weight, etc. I would disagree since they are nothing but rebadged PC's. The G110 and the V2 come with a lifetime warranty when purchased at a Mirror Glaze distributorship but the price is stupid crazy. $250 each. The UDM is exactly the same as the PC-7424XP. There is no need whatsoever Jared to replace the machine that you have. It will work just fine. Link to comment Share on other sites More sharing options...
Bunky Posted March 20, 2010 Share Posted March 20, 2010 Good info Bunky... is there any truth, that your aware of, to the rumors that the G110 has the same guts as the UDM?? I've heard it mentioned more than once in passing, but never have been able to verify if it were true or not. I would say no since Meg's comparison between the UDM and G110 are not the same based upon OPM's, noise level, weight, etc. Link to comment Share on other sites More sharing options...
Chewy Posted March 19, 2010 Share Posted March 19, 2010 I got a good deal on it and it has works great for me. I used it to take some pretty bad rain spot and swirl marks off my black Mustang. I see no reason to buy a new DA until this one let's me down. Agreed 110% I meant no disrespect... Link to comment Share on other sites More sharing options...
Team Adam's Posted March 19, 2010 Share Posted March 19, 2010 The G110 was more powerful than the PC 7424 as measured in OPM's -- about the same as the UDM. It used all the backing plates, etc the PC did. However, it was short lived (2 yrs) and replaced with the G110V2 which is an all new design that rivals the PC XP and other DA polishers. Good info Bunky... is there any truth, that your aware of, to the rumors that the G110 has the same guts as the UDM?? I've heard it mentioned more than once in passing, but never have been able to verify if it were true or not. Link to comment Share on other sites More sharing options...
Bunky Posted March 18, 2010 Share Posted March 18, 2010 The G110 was more powerful than the PC 7424 as measured in OPM's -- about the same as the UDM. It used all the backing plates, etc the PC did. However, it was short lived (2 yrs) and replaced with the G110V2 which is an all new design that rivals the PC XP and other DA polishers. Link to comment Share on other sites More sharing options...
MburgWVDetailer Posted March 18, 2010 Author Share Posted March 18, 2010 For those who care, I like pictures... Definitely NOT a PC D/A... If it is, it looks to be a cheaper design than the PC's we're accustomed to. Chris I got a good deal on it and it has works great for me. I used it to take some pretty bad rain spot and swirl marks off my black Mustang. I see no reason to buy a new DA until this one let's me down. Link to comment Share on other sites More sharing options...
Chewy Posted March 18, 2010 Share Posted March 18, 2010 For those who care, I like pictures... Definitely NOT a PC D/A... If it is, it looks to be a cheaper design than the PC's we're accustomed to. Chris Link to comment Share on other sites More sharing options...
Team Adam's Posted March 18, 2010 Share Posted March 18, 2010 From what I understand the G110 is either a rebranded PC 7424 or UDM machine... in either case the backing plate will work. Link to comment Share on other sites More sharing options...
SaleenJOE Posted March 18, 2010 Share Posted March 18, 2010 they will work. I have the backing plate off maegs DA on my pc and they will fit.If you have the same plate as me its just smaller than the one adams sells with there pad kit. nice thisng about the adams one is it centers the pad where the megs one u have to eye ball it Link to comment Share on other sites More sharing options...
whiterp199 Posted March 18, 2010 Share Posted March 18, 2010 Sorry Jared I am not familiar with this DA. Link to comment Share on other sites More sharing options...
Chris@Adams Posted March 18, 2010 Share Posted March 18, 2010 Sorry Jared I am not familiar with this DA. Link to comment Share on other sites More sharing options...
MburgWVDetailer Posted March 18, 2010 Author Share Posted March 18, 2010 Ive been looking at them and I am starting to think they will work. They both use velcro, so I dont see why it wouldnt work. It just looks like design of the Adams pads will do a better job and look easier to clean. Link to comment Share on other sites More sharing options...
11chevz71 Posted March 18, 2010 Share Posted March 18, 2010 I think they will i am not quite sure. Let see what others have to say Link to comment Share on other sites More sharing options...
MburgWVDetailer
24 answers to this question
