IMADreamer Posted April 13, 2010 Share Posted April 13, 2010 sounds like you need new blades or something. Link to comment Share on other sites More sharing options...
whiterp199 Posted April 13, 2010 Share Posted April 13, 2010 I have a mid-late '90's LT133 riding deere and that is the crappiest mower we have ever had, it wil not cut even for anything and leaves a 1.5-2 inch strip down the middle where it wont cut. No idea about the zero turns, but the rider I have sucks. Atleast it does have a Kohler engine that will run forever. My mower will do this when the blades either get worn or they are out of alignment. I just have to pull the deck off, sharpen the blades, and check the alignment. After that I am good. Link to comment Share on other sites More sharing options...
Chewy Posted April 13, 2010 Share Posted April 13, 2010 My mower will do this when the blades either get worn or they are out of alignment. I just have to pull the deck off, sharpen the blades, and check the alignment. After that I am good. Agreed! It's not the mower... I had a cheap 2nd hand Craftsman that did that. After aligning everything and leveling the deck it was cured! Link to comment Share on other sites More sharing options...
CorvZ061 Posted April 13, 2010 Share Posted April 13, 2010 Agreed! It's not the mower... I had a cheap 2nd hand Craftsman that did that. After aligning everything and leveling the deck it was cured! We've put new blade's on it, leveled the deck, brought back to the Deere dealer and let them "fix" it, but it never gets fixed. the dealer put a whole new deck on it, with new blades, which were already new when I brought it to them. I'm thinking that maybe the deck and blade design is just a bad design, I have 3 friends with the exact same model, and theirs do the same thing. I'm looking a Toro Zero turn with a Kawasaki engine. so maybe I'll just upgrade this time. lol Put that Kohler engine on the Deere on a old Snapper frame and try to have some fun. Link to comment Share on other sites More sharing options...
mcss383 Posted April 13, 2010 Share Posted April 13, 2010 Put that Kohler engine on the Deere on a old Snapper frame and try to have some fun. Just make sure to: 1. Wear a seatbelt to keep you on the mower when it pops wheelie's and... 2. Buy a box of the clutch disks that wear out on those things every season. lol My grand dad's OLD Snapper with the stock motor could pull an easy 20 degree wheelie, if not closer to 30 degrees. Ours which was bought in the 80's would only get a slight hop with a high rpm dump. Link to comment Share on other sites More sharing options...
