Roshi Posted April 8, 2010 Share Posted April 8, 2010 ...if i want to make a second attempt at removing the scratches i didnt get the first time around? Or i can simply start over with SHR? Link to comment Share on other sites More sharing options...
GerryC Posted April 8, 2010 Share Posted April 8, 2010 You need to remove the wax in order to work on the scratches which are on the paint (and under the wax), however either clay/SHR/FMP/Revive will remove the wax anyway, so regardless of which step you start from for your second attempt, you don't need to add any extra step to take the wax off. Link to comment Share on other sites More sharing options...
Sooners Posted April 8, 2010 Share Posted April 8, 2010 You need to remove the wax in order to work on the scratches which are on the paint (and under the wax), however either clay/SHR/FMP/Revive will remove the wax anyway, so regardless of which step you start from for your second attempt, you don't need to add any extra step to take the wax off. Clay and SHR will remove the wax, so when you're done, you'll just have to make sure you apply more wax. Link to comment Share on other sites More sharing options...
Chris@Adams Posted April 9, 2010 Share Posted April 9, 2010 You need to remove the wax in order to work on the scratches which are on the paint (and under the wax), however either clay/SHR/FMP/Revive will remove the wax anyway, so regardless of which step you start from for your second attempt, you don't need to add any extra step to take the wax off. With Gerry! Link to comment Share on other sites More sharing options...
11chevz71 Posted April 9, 2010 Share Posted April 9, 2010 You need to remove the wax in order to work on the scratches which are on the paint (and under the wax), however either clay/SHR/FMP/Revive will remove the wax anyway, so regardless of which step you start from for your second attempt, you don't need to add any extra step to take the wax off. Link to comment Share on other sites More sharing options...
Roshi
4 answers to this question
