4" pad adapter problem!!
mobilman
So I did a full detail on my car this weekend (pics to come) and I used the 4" pads in the areas that needed them. Well I used the normal pads in the areas that I could and applied SHR and FMP... then I switched to the 4" pads to apply the SHR and FMP it the other areas.... etc.
But when I went to take off the adapter I realized... how do I get it off? :help::help:
Because Its on a baring it can spin freely in either direction so it can't just unscrew. I'm very mechanically inclined but I'm at a blank here. There is no room to hold the bearing in place or anything, the baring doesn't come out... what do I do :confused::confused:
you should have the wrench that came with your pc to hold the shaft of the machine
then you can use another wrench to loosen that piece
haha now i feel really dumb.
For some reason I thought the entire piece went into the bearing. Like you can see the piece that is in there now... I thought that was part of the adapter hahah. problem fixed tho.
THANKS FOR THE HELP!
LOL I read the first post and was like... "is this guy serious or is he having a funny with us?"
lol
Glad you got it sorted M8.
Chris
