The Ryan Posted April 14, 2010 Share Posted April 14, 2010 I was ready to purchase a new wheel for my camaro due to some road rash it got 2 weeks after buying the car.. $480 for a wheel was a bit pricey, so I did some research, and found a so cal business "Dr Wheel." Great service, same day appt. priced as quoted, only took 45min. Not 100% I still know where it is, but my wife can't find it anymore. Saved me $405... I'm happy! Before: After: Link to comment Share on other sites More sharing options...
Nordgrey Posted April 14, 2010 Share Posted April 14, 2010 Nice! Not much wonder your wife can't spot it. Looks like great work. Only $75? Link to comment Share on other sites More sharing options...
StormChaser Posted April 15, 2010 Share Posted April 15, 2010 That's pretty amazing...wonder will it ever chip back off or anything?? That is definitely a good find! Link to comment Share on other sites More sharing options...
Chris@Adams Posted April 15, 2010 Share Posted April 15, 2010 Did they have to dismount tire? They did a great job! Link to comment Share on other sites More sharing options...
The Ryan Posted April 15, 2010 Author Share Posted April 15, 2010 Nope.. Basically they use a grinder, ground down the damaged area; then ground down about 12" of wheel to "blend" the paint and the wheel ( they don't use any fillers ). Once they have a neat even surface from the grinder, they mix a lacquer based paint by hand (this was impressive) reshoot the area with a airbrush (and blend); re-clear; done. The rim stayed on the car.. it took about 45 minutes because the silver on these camaro's has a black base coat, so it was a bit more difficult to match.. Overall I'm VERY happy with this form of repair. It's 99% and just like paint correction, you just can't be overly critical. Link to comment Share on other sites More sharing options...
Sooners Posted April 15, 2010 Share Posted April 15, 2010 Nope.. Basically they use a grinder, ground down the damaged area; then ground down about 12" of wheel to "blend" the paint and the wheel ( they don't use any fillers ). Once they have a neat even surface from the grinder, they mix a lacquer based paint by hand (this was impressive) reshoot the area with a airbrush (and blend); re-clear; done. The rim stayed on the car.. it took about 45 minutes because the silver on these camaro's has a black base coat, so it was a bit more difficult to match.. Overall I'm VERY happy with this form of repair. It's 99% and just like paint correction, you just can't be overly critical. I had a wheel repaired several months ago, and it sounds like your experience was a positive one like mine. I also paid $75 for the repair, and the wheel looks good as new. Tire stayed on the car. My wheels also have a black base coat. Sounds like the process was extremely similar. Looks good! Link to comment Share on other sites More sharing options...
b_pappy Posted April 15, 2010 Share Posted April 15, 2010 Nice job, looks good. Bruce Link to comment Share on other sites More sharing options...
whiterp199 Posted April 15, 2010 Share Posted April 15, 2010 I am impressed. That looks good. Link to comment Share on other sites More sharing options...
Chewy Posted April 15, 2010 Share Posted April 15, 2010 I could tell they rounded it down but ONLY because you pointed it out. I'd be VERY happy with that repair. Remember... No wax on it for a month or so! Chris Link to comment Share on other sites More sharing options...
