jpu471 Posted April 24, 2010 Share Posted April 24, 2010 How long between coats of Buttery and can you use Brilliant Spray Glaze in the sun thanks I will take my answer off the air Link to comment Share on other sites More sharing options...
Marylander Posted April 24, 2010 Share Posted April 24, 2010 You can apply two or more coats of buttery consecutively, but there's no real reason to do so. You'd get better (longer lasting) protection by doing a coat of Americana or MSW and then just using BW every once in a while for some added "wow". But generally speaking BW doesn't offer the same longer-term protection as the others. And yes, it's fine to use BW in the sun. Link to comment Share on other sites More sharing options...
whiterp199 Posted April 24, 2010 Share Posted April 24, 2010 I use BSG in the sun all the time. I have never used it on a day where the temperature was above 70 though. Link to comment Share on other sites More sharing options...
Chris@Adams Posted April 25, 2010 Share Posted April 25, 2010 You can apply two or more coats of buttery consecutively, but there's no real reason to do so. You'd get better (longer lasting) protection by doing a coat of Americana or MSW and then just using BW every once in a while for some added "wow". But generally speaking BW doesn't offer the same longer-term protection as the others. And yes, it's fine to use BW in the sun. Rich hit the nail on the head! Link to comment Share on other sites More sharing options...
jpu471
3 answers to this question
