6spdg37s Posted April 25, 2010 Share Posted April 25, 2010 So, NJ state inspection, I need a front plate... I cant zip tie it to the front fascia because it doesnt fit... the plate is wider than the fascia is... I have a bracket from the viper that I am trying to cut down to fit but it may not work... So I really dont want to pay 180 bucks for a removable new one to have it on for a whole 5 mins... does anyone have any tips of how I can make this quickly and cheaply Link to comment Share on other sites More sharing options...
Chris@Adams Posted April 25, 2010 Share Posted April 25, 2010 Would velcro work or 3M double sided tape? Link to comment Share on other sites More sharing options...
whiterp199 Posted April 25, 2010 Share Posted April 25, 2010 Can you Zip Tie some spacers onto the fascia and then attachment the plat to the spacers. If you can give us a pic I may be able to mentally rig something else up. Link to comment Share on other sites More sharing options...
6spdg37s Posted April 25, 2010 Author Share Posted April 25, 2010 here... just a general z06 pic ...mines in the garage and its raining out so im not gona get a pic of it... inside the front fascia theres like diamond shaped mesh.. and the plate cant fit all the way in it has to be out and flush with the bumper cause its way to narrow to fit it Link to comment Share on other sites More sharing options...
whiterp199 Posted April 25, 2010 Share Posted April 25, 2010 What if you got two small blocks of wood? Probably 1x1s. You can screw the plate to the blocks and run a clamp behind the blocks, attaching the blocks to the mesh. Link to comment Share on other sites More sharing options...
6spdg37s Posted April 25, 2010 Author Share Posted April 25, 2010 I was thinking about similar but using some sort of rubber but yes I could try the wood. Link to comment Share on other sites More sharing options...
Marylander Posted April 25, 2010 Share Posted April 25, 2010 I was thinking about similar but using some sort of rubber but yes I could try the wood. What about a couple of adam's square foam applicator pads? They would crush to shape and not risk scratching or rubbing the paint. Link to comment Share on other sites More sharing options...
whiterp199 Posted April 25, 2010 Share Posted April 25, 2010 Rubber or plastic could work as well. You could also attach the plate to something and then attach whatever the plate is attached to to the under side of the front fascia. You could use Velcro or double sided tape for this. You could even put velcro on the underside of the top lip above the fascia. You could then take the plate on and off when ever you needed to. Plus the velcro would be hidden by the over hang. Link to comment Share on other sites More sharing options...
6spdg37s Posted April 26, 2010 Author Share Posted April 26, 2010 ^ the plate doesnt fit in the fascia thats the issue... and I cant hang it off the lower plastic piece cause it touches the ground ... I like the wood or rubber or plastic square idea though.. I need to brainstorm I also want to continue to cut down the viper bracket...since I have that already its not being used obviously.. if that fits once cut itll work the best Link to comment Share on other sites More sharing options...
whiterp199 Posted April 26, 2010 Share Posted April 26, 2010 Could oyu put it on the upper part of the lower fascia? I drew an arrow to the area I ws thinking, or is that too low as well. Link to comment Share on other sites More sharing options...
6spdg37s Posted April 26, 2010 Author Share Posted April 26, 2010 yea the plate is to wide to fit.. and its too deep to even ziptie and have dangle.. it would have to be bent alot and im pretty sure thats illegal as well... Link to comment Share on other sites More sharing options...
03silvss Posted April 26, 2010 Share Posted April 26, 2010 can you some how get some bolts like used when putting on a grill that can slip in behind and then expand behind that plastic honeycomb and then drill a couple small holes through the licence plate and put some nuts on to tighten it up, and if you dont want it touching the paint just put something soft in between the plate and the car before you tighten it up. problem solved and should look awesome Link to comment Share on other sites More sharing options...
