19stang88 Posted May 3, 2010 Share Posted May 3, 2010 I want to get a drill from my 4 inch pads. I want to know what kind of drill should i get. any suggestions? Link to comment Share on other sites More sharing options...
duramaxsky Posted May 3, 2010 Share Posted May 3, 2010 I also have A question in this area. The 4" pads come with A mandrel that is threaded. It fits the polisher. Is it OK to use the 4" pads on the polisher? Link to comment Share on other sites More sharing options...
whiterp199 Posted May 3, 2010 Share Posted May 3, 2010 I also have A question in this area. The 4" pads come with A mandrel that is threaded. It fits the polisher. Is it OK to use the 4" pads on the polisher? Yes sir. You can either use them on the drill or the pc. They are good on the PC for smaller areas. Link to comment Share on other sites More sharing options...
duramaxsky Posted May 3, 2010 Share Posted May 3, 2010 Thanks I was afraid it may be too much for them. Link to comment Share on other sites More sharing options...
19stang88 Posted May 3, 2010 Author Share Posted May 3, 2010 I know i can install them to the pc but i want to be able to have a drill that can act as a rotary for hard to remove scratches. Link to comment Share on other sites More sharing options...
The Ryan Posted May 3, 2010 Share Posted May 3, 2010 I use a 12v Rigid, with variable speed trigger. I have a 18v dewalt XRP, but it will heat up the paint too fast. Link to comment Share on other sites More sharing options...
Chewy Posted May 3, 2010 Share Posted May 3, 2010 I've used my LI Ion 12 volt B&D drill but for good scratch removal I use my B&D 110vac old school drill. It gives me MUCH more power and much longer run times. I just finished doing correction on my G8 and IMO the 4" pads are a necessity. Being a DD means it has some deep scratches in the finish. The only quick way to remove them is with a rotary. Well the 4" pads fit the bill. LOVE THEM! Chris Link to comment Share on other sites More sharing options...
Chris@Adams Posted May 3, 2010 Share Posted May 3, 2010 Battery drill is best, I have a 14v Dewalt.:burnout:The 14v has plenty power and its not to heavy. Link to comment Share on other sites More sharing options...
19stang88 Posted May 3, 2010 Author Share Posted May 3, 2010 as for RPM, what should i be looking for? Link to comment Share on other sites More sharing options...
Scoobah St3ve Posted May 8, 2010 Share Posted May 8, 2010 Yea I am wondering the same thing... I need a drill for headlight restoration. Thats easy money lol. Link to comment Share on other sites More sharing options...
McDuff Posted May 8, 2010 Share Posted May 8, 2010 I find that since the 4" pad concentrates things so much that I don't use the high speed RPM and I have learned from the forum that you can build up heat so watch out for that. Link to comment Share on other sites More sharing options...
whiterp199 Posted May 8, 2010 Share Posted May 8, 2010 I find that since the 4" pad concentrates things so much that I don't use the high speed RPM and I have learned from the forum that you can build up heat so watch out for that. I used the four inch pad on the PC at about 5500 and it built up some serious heat. The four inch pads can heat up. Link to comment Share on other sites More sharing options...
19stang88
11 answers to this question
